Modifying PS Pump bracket to clear aluminum heads
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
My 66 has the drivers side power steering pump bracket (non AC w/ alternator on pass side)
The bottom part of the PS pump Bracket catches a single stud that comes out of the front of the block just below the head.
Aluminium heads protrude from the front of the block 1/2" unlike the original cast heads which only had the accessory bosses only protruding- So the PS pump bracket doesn't fit quite right.
Looking to see what other people with aluminum heads have done with this bracket.
I think i'm going to cut the bottom off the bracket this weekend, which will allow it to clear properly and sit flat like it should- the question then is weather or not to bend up and weld that lower tab back onto the main bracket or just to leave it off...
There are already two bolts attaching it to the end of the head itself, and one more "tang" that catches the first exhaust flange bolt on the side. I think that would be beefy enough to hold this thing...
Any thoughts?
Any thoughts?
Pics from the bottom:
in this pic, the two upper bolts that attach to the end of the head are in- and you can see how the "bend" in the metal for the lower stud hole is holding it from sitting flush on the head.
With it like that I bet the pump isn't straight with the other pulleys. Might need more work than just bending the bracket around.
I know the water jacket is pretty close to the front bottom of the head from the issues folks have with trimming for mechanical fuel pumps. Looks like quite a chunk would have to come off, so I'd be worried. Probably best to get ahold of one of the guys on ROP to see if they know about the routing in that corner.
I'm going to cut the bracket and cut that tang and obstruction off. Then I'll decide if I need to weld a new tang on. That bracket is very very thick metal. Much easier to cut and weld than try to bend or hammer it!
Before: IMG_20130717_224444_930_zps4d7c7f6b.jpg
After Cutting:
Getting very close. Worked on the new flowmaster exhaust system today. Will wrap that up this week- need a little more time on this bracket- and then its just finish bolting stuff together and it'll be ready to fire.
Couple more weeks at my snails pace- but i'm getting excited.
After Cutting:
69442C
July 20th, 2023 03:13 PM
Del70
September 30th, 2014 07:21 PM
NorCalAndy
September 27th, 2009 08:59 PM
