Mirroring a build
Old Jan 13, 2009 | 01:27 PM
Charlie_brown's Avatar
Mirroring a build
Does any one know any other builds that have been done i have plans on just coping a build that car craft did some years ago. looK! This too for the numbers they got and the parts they used it seems easiest way to get the numbers i wanted. This is my first engine build and i just wanted an opinion.
*Don't wanna bore it .60 over is there any other way to get around the same numbers with stock or .30 bore?
Old Jan 13, 2009 | 02:46 PM
gearheads78's Avatar
car guy
Will make no real difference. You bore only as much as you need to save as much wall thickness as possible. I would not worry about it.
Old Jan 13, 2009 | 04:12 PM
What he said. From the Car Craft article:
Originally Posted by Car Craft Magazine
The junkyard block had already been rebuilt once before, so it was bored 0.060-over,
If you're worried about matching their HP and torque numbers, 6 cu inches (the difference between an 0.030" and 0.060" overbore on an Olds 455) is negligible. Keep in mind that's only a 1.5% difference in displacement. Be more worried about workmanship and assembly details.
Old Jan 14, 2009 | 03:24 AM
mugzilla's Avatar
is Fast Enough ...
I'm going to replace gaskets and seals on my motor. What do you think about the Ford rear main gasket ...
Originally Posted by Hot Rod Mag
Olds engines use a one-piece metal valley pan to seal the intake manifold to the heads; it doesnt work well with aluminum heads and intakes.
What do you guys recommend ..?
Old Jan 14, 2009 | 10:30 AM
Smart thing to do.
I have never had a problem with the factory turkey tray intake gasket. I've used it on iron intakes, factory aluminum intakes, and aftermarket aluminum intakes and never had a leak. I have not had the chance to use it on aluminum heads yet, but I don't see why that would be an issue. I suspect that the problem people have is that they do not properly seat the four raised locating bosses in the bolt holes on the heads. This would cause the gasket to move or leak.
Old Jan 14, 2009 | 04:31 PM
bigoldscruiser's Avatar
2 '66 98's
I have used the Ford seal on my last two builds on 425's and have excellent results. Would recommend it to anyone. Bruce
Old Jan 14, 2009 | 04:48 PM
The rope seals also work well if they are installed properly. Don't try to install one using a Sneaky Pete though.
Old Jan 14, 2009 | 05:16 PM
citcapp's Avatar
I agree the 460 ford seal is the only way to go
Old Jan 20, 2009 | 11:08 AM
88 coupe's Avatar
Junior Member
........ my first engine build and i just wanted an opinion ........
…..... Westech turned the engine over to Dougan's Engine Rebuilding ….....
For anyone in the So CA area, they are more than competent.
9072 Limonite Ave
RIVERSIDE, CA 92509 USA
(951) 681-1961
…..... The block was surfaced to square-up the decks, then align-honed to true up the main-bearing bores for the stock crank, which was cross-drilled for improved oiling ….....
Not necessary at this power level, but can't hurt. Let your budget be your guide.
…..... The desirable Olds nodular-iron crank has an "N" (shown) or "CN" cast on the No. 1 counterweight ........
"N" or "CN" doesn't mean much, if the ones with no markings were also cast from the same nodular iron.
Just use the one that came with the engine.
…..... Westech feels an intake optimized for higher-rpm performance--such as a Performer RPM or even a Victor Jr.--is needed to fully unleash the potential of Edelbrock's Olds heads ….....
There are no RPM or Victor Jr level intakes for 400/425/455 Olds, but the Edelbrock Torker would be a good choice.
Like many other “sources” the information in those “magazines” should always be taken with a grain of salt.
Norm
Old Jan 20, 2009 | 11:36 AM
Actually, Edelbrock now makes a Victor for both SBO and BBO:
Note that this is not the old Victor for Batten heads. These are new designs for OEM or Edelbrock heads. In particular, the SBO Victor is designed to mate to the larger ports of the Edelbrock heads (or BBO heads, presumably) when used on a small block.
Yes, it's not a Victor Jr, it's a Victor. From what I can tell, the difference is about 500 RPM shift in the design operating point (Victor Jr appears to be sized for 3000 - 7500 RPM, the full Victor for 3500 - 8000 RPM). In any case, the bottom end and heads need to be built to run at those RPM ranges if you plan to use the airflow capability of this intake. As with all engine components, all the parts need to be selected to match the intended usage and operating conditions.
Old Jan 20, 2009 | 01:43 PM
88 coupe's Avatar
Junior Member
Actually, Edelbrock now makes a Victor for both ........
Correct. They have for several years.
In Edelbrock speak, Victor level is all out competition. Victor Jr, bridges the gap between it and the RPM (street/strip) level.
........ These are new designs for OEM or Edelbrock heads ........
I am only familiar with the BB version. Prior to its release, I attended a seminar, that was put on by the engineer that designed it. It was designed/optimized for use with Edelbrock heads, at RPM ranges that few "street" engines will ever see.
Edelbrock gambled that, if the "Victor level" racers were given the manifold they needed, their quicker/faster numbers would create a demand for a "Victor Jr" for the lower level competitors.
As far as I know, that demand has not yet been created.
........ From what I can tell, the difference is about 500 RPM shift in the design operating point (Victor Jr appears to be sized for 3000 - 7500 RPM, the full Victor for 3500 - 8000 RPM) ........
Where did you find specs/numbers for a Victor Jr?
........ There are no RPM or Victor Jr level intakes for 400/425/455 Olds ........
If a Victor Jr is available for this application, it is the only logical choice.
Norm
Old Jan 20, 2009 | 02:48 PM
Norm
I was looking at Edelbrock's descriptions for their BBC manifolds. It appears that their "Victor" brand manifolds are advertised as 3500-8000 RPM. The "Victor Jr" brand is advertised as 3000-7500 RPM. No, there is not a Victor Jr for Olds motors.
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
69 442 protour
Dec 9, 2006 09:25 PM
mainedogg72
Jul 7, 2006 12:17 AM
rodknocker
Apr 17, 2006 08:25 PM
