mild cam for driver
Old Dec 24, 2019 | 07:03 AM
VinMichael's Avatar
mild cam for driver
Putting together a stock high compression short block with big valve G heads and stock 4 barrel intake manifold. Carb will be a Holley 750 vac secondary. Car has headers and 3.73ish gears. Mild converter and th350. Rpm range idle-4,800
I want something that will work with stock valve train.
Would a Lunati voodoo 262/268 be a good choice
Or maybe a Comp 268H
I already have Comp double springs which are 105 lbs on the seat. They require .530 positive Teflon seals.
Old Dec 24, 2019 | 07:22 AM
Talk to cutlassefi. Mark will set you up with the right grind. He did a cam for my 67 D88 with a large LSA that makes good power and excellent vacuum for the brake booster and HVAC.
Old Dec 24, 2019 | 08:01 AM
VinMichael's Avatar
would you say it’s worth upgrading the cam and lifters? I have the stock cam and lifters. The lifters are just dirty with old black oil from what I see. Might be fine after cleaning them off with some solvent. Not sure.
my car is a 64 f85 with power brakes.
Old Dec 24, 2019 | 09:37 AM
cutlassefi's Avatar
Erson Hi Flow 1 if you have 9.0:1 or better. It’s 228/228@.050. If you’re above 9.5:1 then do a TQ50. Both will be easier on the valvetrain than what you listed.
Old Dec 24, 2019 | 10:48 AM
VinMichael's Avatar
9.4:1 right now without decking
what kind of power can I expect to make on a good day with the Hi Flow 1. The engine is all stock but in decent shape. 2.5” dual exhaust. At sea level.
Old Dec 24, 2019 | 11:29 AM
cutlassefi's Avatar
what kind of power can i expect to make on a good day with the hi flow 1. The engine is all stock but in decent shape. 2.5” dual exhaust. At sea level.
375-400.
Old Dec 24, 2019 | 12:57 PM
VinMichael's Avatar
375-400.
I’ll send a PM when ready
Oldsmaniac84
Jun 11, 2019 02:05 PM
marklt
Apr 23, 2015 06:11 PM
yankees
Jul 18, 2013 08:30 AM
Velacyn
Mar 7, 2013 03:10 PM
GoldOlds
Nov 11, 2007 07:22 PM
