mild cam for driver
mild cam for driver
Putting together a stock high compression short block with big valve G heads and stock 4 barrel intake manifold. Carb will be a Holley 750 vac secondary. Car has headers and 3.73ish gears. Mild converter and th350. Rpm range idle-4,800
I want something that will work with stock valve train.
Would a Lunati voodoo 262/268 be a good choice
Or maybe a Comp 268H
I already have Comp double springs which are 105 lbs on the seat. They require .530 positive Teflon seals.
my car is a 64 f85 with power brakes.
what kind of power can I expect to make on a good day with the Hi Flow 1. The engine is all stock but in decent shape. 2.5” dual exhaust. At sea level.
