Melling HV oil pump with stock shaft
Old Dec 15, 2017 | 03:51 PM
Macadoo's Avatar
Well, crud. At the risk of being flamed, I installed the new HV oil pump with the stock shaft before I realized that melling offers their own. The pan is now installed with rtv and cork gasket. Do I need to pull it or will the stock shaft be okay? It seems to mate up with pump just fine but I haven't tested the distributor.
455, 30 over, wiseco pistons, ARP main studs, rod bolts, head bolts, 9.8:1 CR, HEI, stock crank, running .030 crank clearances.
Old Dec 15, 2017 | 03:55 PM
cutlassefi's Avatar
You’re fine.
Old Dec 15, 2017 | 04:19 PM
Macadoo's Avatar
Perfect. Thanks Mark. You're the man!
Old Dec 16, 2017 | 08:22 AM
Run to Rund's Avatar
I agree, run it.
Old Dec 16, 2017 | 08:46 AM
Macadoo's Avatar
Originally Posted by Run to Rund
I agree, run it.
Thanks Rund. I appreciate the input.
Old Dec 19, 2017 | 11:52 AM
VinMichael's Avatar
I think you missed a zero on your crank clearance
Old Dec 19, 2017 | 04:16 PM
Macadoo's Avatar
Three-hundredths a little too big? Lol, yeah, seems I'm always doing that.
Qwik71442
Mar 9, 2016 08:43 PM
cdrod
Dec 14, 2015 01:10 PM
MDchanic
Mar 25, 2013 05:01 AM
88hurstolds
Oct 6, 2011 08:26 PM
Redog
Jul 22, 2011 07:25 PM
