Melling HV oil pump bolts?
Old Apr 15, 2011 | 11:50 AM
Redog's Avatar
Hey all.
Still waiting on my "20480" Moroso oil pan to get done at the powdercoating shop and I'm looking to start putting together the pick-up to the pump
What size bolts and lenght do I need to connect it. Will just a regular bolts from Home Depot work? I was goiong to use lock washers too. Good idea?
Old Apr 15, 2011 | 04:10 PM
Redog's Avatar
*BUMP*
Nobody knows the answer to this?
Old Apr 15, 2011 | 04:31 PM
Lalo442's Avatar
I would think as long as it is Grade 5 or better ...maybe some lock-tite red on the threads ...
Old Jul 22, 2011 | 02:11 PM
Redog's Avatar
Exclamation
I'm looking to put in the new oil pump this weekend. Does anybody know what bolt size for the pump and pick-up?
Can I re-use the bolts on the oil pump? I'm pretty sure the pick-up is press fit. I'm putting in a bolt on pick up so I'll need to know what size bolts I'll need
Old Jul 22, 2011 | 02:29 PM
TripDeuces's Avatar
Is something wrong with the old bolts? If not use them.
Old Jul 22, 2011 | 04:07 PM
Redog's Avatar
IDK I haven't taken the pan off yet.
However the old bolts on the pickup will be a problem, because they are not there. I'm taking out the stock 330 pump and replacing it with a HV Melling oil pump and the pick-up matches the new deeper oil pan I bought
Old Jul 22, 2011 | 05:59 PM
TripDeuces's Avatar
If you're talking about the little bolts that hold the pick up to the pump aren't they just 5/16 x 1/2 inch? I doubt the original pump has that arrangement. It's more than likely pressed into the pump body. You'll have to make a trip to the hardware store, bring the pump with you.
Old Jul 22, 2011 | 06:46 PM
Redog's Avatar
Yeah that's what I'm going to be doing. Just trying to save a trip
Old Jul 22, 2011 | 07:25 PM
Yeah - you can't use the words "$ave" and "Oldsmobile" in the same sentence .
nolabigdawg
Oct 25, 2014 11:50 AM
MDchanic
Mar 25, 2013 05:01 AM
naphtali5725
Mar 6, 2013 09:42 AM
Feb 5, 2012 08:21 AM
88hurstolds
Oct 6, 2011 08:26 PM
