Lumpy idle 71 442 with Mondello JM20-22 Camshaft
Old August 16th, 2016, 09:34 AM
  #41
Originally Posted by TripDeuces
You're not moving the valve end Joe.
Which is why I said "the valve end of the rocker is fixed."
The rocker pivots around the valve end. The trunnion moves down 0.063". The pushrod end moves 0.102". Do the math. The pushrod end moves 0.063 x (1+1.6)/1.6 = .102
joe_padavano is online now
Old August 16th, 2016, 09:44 AM
  #42
TripDeuces's Avatar
That's incorrect. The push rod pushes the rocker arm imparting a 1.6 to 1 ration on the VALVE end. Not the other way around. I know you'll agree the cam lobe is always smaller than valve lift. For a cam with a .296 lobe lift you have .474 lift at the valve.
.296 x 1.6 = .474. It doesn't work backwards. The distance between the rocker arm trunnion and the pushrod cup is 1 while the distance between the trunnion and the valve tip is 1.6 of the distance.
TripDeuces is offline
Old August 16th, 2016, 09:49 AM
  #43
Exactly what I said, ASSUMING the rocker is pivoting around the trunnion.
In the case of setting lifter preload, you are actually moving the trunnion downwards, with the valve end acting as the pivot point. That means that for every amount you move the trunnion, the pushrod end moves (1+1.6)/1.6 as much. Draw a diagram.
Old August 16th, 2016, 10:07 AM
  #44
Here's the diagram:
1964F85
November 13th, 2019 08:40 PM
p518
March 16th, 2013 06:16 AM
TheBirds
January 10th, 2013 08:19 AM
nonhog
July 30th, 2012 03:18 PM
73rocketship
July 6th, 2012 06:45 AM
Quick Reply: Lumpy idle 71 442 with Mondello JM20-22 Camshaft
