lost with a 455
Old Jun 26, 2011 | 08:32 AM
2000anderson's Avatar
Cool lost with a 455
I have a 455 out of a 72 olds it has a set of g heads, are they a good set of heads or should i get and after market set of heads? Does anyone
know the cc of the chambers and size of the valves. Does anyone know
the stock comp of this 455? I'm going to build it and try to get around
9.5 to 1 so i can run pump gas.
Thank you in advance
Old Jun 26, 2011 | 11:06 AM
cutlassefi's Avatar
Use the G's, put 2.07 valves in them and use the L2323 Speed Pro piston. Depending on deck and head cc that should get you around 9.5-9.75:1.
Jmo
Old Jun 27, 2011 | 11:23 AM
Thanks for the info. I s their a place where I can get a crank kit to stroke this motor?
Old Jun 27, 2011 | 06:40 PM
cutlassefi's Avatar
Eagle, or offset grind the one you have.
runnin350
Feb 2, 2014 06:37 AM
Odmark
Feb 6, 2013 07:10 AM
Chumley
Mar 16, 2009 07:30 PM
frdmftr
Sep 5, 2007 11:20 AM
shaunr
Dec 23, 2006 07:55 AM
