loosing oil presure, again
Old Apr 2, 2009 | 04:39 PM
442 Guatemala's Avatar
Thumbs down loosing oil presure, again
Hi, many of you know in December i just rebuild my 400 engine for my 1966 442. in this time when I start my engine I loose my oil presure and I damage the main bearings, rod bearings and cam bearings.
When I opened the engine I found some problems: Main bearings and Rod bearings clearances wasnt good.
So I start again, I buy new Rod, Main and Cam bearings. I install oil restrictors on mains 2,3,4 I change the oil pump spring to increase the oil pressure. Im using a new stock oil pump and my stock oil pan. (I really dont know the capacity of my oil sotck pan???)
I leave the Main clearances in 0.002, Rod clearances 0.001.
On my cam bearings I have 0.0055 of clearance, is that too much??? thats why im loosing oil pressure???
To help oil return from the heads I drill in each head a new 1/2" holes in the back, and I connect them with a hose to a new holes I made to the block.
Today I star my engine again, I prime my engine first I use 5w 30 oil, then I start the engine and I have like 40psi in Idle, a few seconds later oil presure start going down, to like 25psi, when I accelerate the car I go up to 50psi fo like 10 seconds, 10 seconds later I start loosing presure to 20-25psi.
I talk to Mondello and this guy Linn told me that I need to change my oil pan for a biger one 8 Qts and need a new Hig volume, Hig Presure pump, because im getting out of oil???? Is that a good Idea??
please any help and comments are welcome
thanks
Alex
Old Apr 2, 2009 | 04:57 PM
jensenracing77's Avatar
you should have 5 Qts of oil in it. it is hard for me to believe that you are starving for oil. Linn is good but i think he may be selling you something you don't need. 25 psi of oil would not bother me. pressure is not necessarily the key. you want oil flow. if you have alot of oil flow you will be good. with high oil pressure you may not have high oil flow. the faster you can bump the oil through, the cooler the barrings will be.
don't know if this helps but i am just rambling.
Old Apr 2, 2009 | 05:00 PM
after reading again, i think that is around what my car does. i may be a little lower at idle and at operating temps.
Old Apr 2, 2009 | 06:48 PM
thanks
Alex
5W-30 is too thin. Your engine should use 10W-40.
Old Apr 2, 2009 | 09:35 PM
geckonz08's Avatar
shouldn`t his clearances on the mains be .003 and rods .002 ??
mike
Old Apr 2, 2009 | 09:50 PM
88 coupe's Avatar
Junior Member
........ this time when I start my engine I lose my oil pressure and I damage the main bearings, rod bearings and cam bearings ........
What RPM, and for how long?
........ cam bearings I have 0.0055 of clearance ........
For a "stock" engine, the manual says .0012" to .0050". .0055" is a bit loose but a high volume pump can easily handle any excess oil flow. If valve spring tensions were increased, clearances would have to be smaller.
Having said that: Consider how those "restrictors" in your 2, 3, and 4 mains, affected the flow to your cam bearings.
........ it is hard for me to believe that you are starving for oil ........
It would be possible (with those main/rod clearances) if it was held at over 5000 RPM for several minutes.
........ i think he may be selling you something you don't need ........
Not surprising. He is in business to sell oil pumps, pans, restrictors, etc.
8qt pans with 5 or 6qts, are helpful in controlling windage, but then ground clearance can become an issue.
........ if you have a lot of oil flow you will be good. with high oil pressure you may not have high oil flow. the faster you can bump the oil through, the cooler the barrings will be ........
Correct. You can have all the pressure in the world, but without flow there will be no lubrication. Likewise, you can have all the flow in the world, but without pressure there will be no lubrication.
Norm
Old Apr 2, 2009 | 10:35 PM
88 coupe's Avatar
Junior Member
5W-30 is too thin ........
Lighter oil will flow through the system easier, and return to the pan in less time.
Originally Posted by geckonz08
shouldn`t his clearances on the mains be .003 and rods .002 ? ........
Yes. For a "performance engine, the rule of thumb: .001" per 1" of journal, or .003" on 1, 2, 3, & 4, and 0025" on the rods, in this case. The exception is .0035" on main #5,
More for a "racing" engine. Less for one that is intended go 300,000 miles or more.
Norm
Old Apr 2, 2009 | 10:53 PM
I use 5w 30 just for prime the engine and the first 10 minutes, then I change to a 15w 40. Im using Castrol multigrade
Old Apr 2, 2009 | 11:03 PM
[QUOTE=88 coupe;73296]What RPM, and for how long?
I start my engine outside the car, so I dont know thr RPM, I start the car the first time for 10 min with 5w 30, then I change to 15w 40.
To be exactly for cam clearances I have:
No. 1, 0.004, No. 2. .0.005, No. 3. 0.005, No. 4 0.0055 and No. 5 0.004
as for Oil Flow I think I have good oil flow, because the oil is covering all my valve covers and they are leaking a little bit. What is the minimun oil pressure recomended for the 400 engine?? are you runnig near 25-30psi??
I have some videos when I start my engine, im going to try to uploaded so you can see
Old Apr 3, 2009 | 12:05 AM
88 coupe's Avatar
Junior Member
........ What is the minimun oil pressure recomended for the 400 engine? ........
The book says 35-45. I would not expect to see that much at a warm idle.
........ are you running near 25-30psi? ........
My 425 was about 10 lb @ 700 RPM and just over 50 lb @ 7000.
........ I have some videos when I start my engine ........ I'm going to try to uploaded so you can see
That will help.
Norm
Old Apr 3, 2009 | 09:44 AM
[QUOTE=88 coupe;73308]The book says 35-45. I would not expect to see that much at a warm idle.
You run on 10lb at 700 RPM without any problem?
Why in the mondello technical manual says that less than 20psi is unsafe and not recomended to be operated?
Norm, can you tell me how to upload a picture or video, I never do that before
thanks
Old Apr 3, 2009 | 11:32 AM
Oldsmaniac's Avatar
Was the block and crank and rods etc properly machined in the rebuild? Oil pressure will naturally drop as the engine temperature goes up. Did you replace the oil pump again or just shim the spring?.....perhaps the pump is defective. Possibly this drop in pressure is not enough to cause engine damage. I once read a dyno test on the 425 done back in 1965 and they commented on the low oil pressure during the test on a factory new engine however when they disassembled the engine there was no damage to the bearings.
Old Apr 3, 2009 | 11:40 AM
Yes the block was properly machined, I double check everithing.
what I dont understand is when I just start the engine I have 40psi, after a few minutes start going down to like 20-25 psi. When I accelerate the car the presure go up to 40 again, but if I keep accelerating the car there is a moment when the presure goes down again. like the pan is empty???
I Dont replace the oil pump, just the spring.
Old Apr 3, 2009 | 12:24 PM
The oil pressure is always highest when the oil is cold. As it warms up it thins out and pressure drops. As the engine speed increases, pressure usually goes up. If you are seeing a drop after hard acceleration, one of two things may be at fault. First is that you have uncovered the pickup and are sucking air. The second is that the oil level is too high and the crank is whipping the oil to a foam.
Old Apr 3, 2009 | 09:15 PM
here are some photos of my engine
Old Apr 3, 2009 | 10:32 PM
88 coupe's Avatar
Junior Member
........ Why in the Mondello technical manual says that less than 20psi is unsafe and not recommended to be operated? ........
It is all relative. At 2000 RPM (under power) 20 lb would be a reasonable minimum to set. At less than 1000 (unloaded) anything over 5 lb would be more than safe.
........ I just start the engine I have 40psi, after a few minutes start going down to like 20-25 psi .........
I have seen this happen with one rebuild. .020" under bearings on a .010" under crank. Bearings were improperly packaged and the "assembler" did not verify the clearances.
In a similar case, pressure was there during cam break in, but went down to 0 after being driven for less than a block. The new pump was DOA.
........ I Don't replace the oil pump ........
Put a new high volume pump in it, and remove the "restrictors" so the cam bearings will get enough oil.
Norm
Old Apr 4, 2009 | 10:27 AM
A 7 Qt oil pan, and a new Hig volume, Hig pressure oil pump, with new pick'up, will help me to solve the problem? or I need a bigger oil pan like 8 Qt?
Old Apr 7, 2009 | 02:14 PM
Hello, today I posted a video in youtube when I show how my oil pressure stay in Idle, and when accelerate the car, goes up, and then goes down again. maybe this video can give you a better Idea on what is happenign to me.
you can go to the link below to see the video.
http://www.youtube.com/watch?v=6lwpS5qhaCU
Today I also call Oldsmobile Performance Products, asking for assistance. The guy asked me what oil filter im using on my car, I say FRAM PH25, he says, FRAM is not a good choice for my car, and maybe that is all the problem, he told me to Change the filter for a WIX or NAPA, is that possible that oil filter can make you loose oil pressure???
thanks for all the comments and advices
Alex
Old Apr 7, 2009 | 02:43 PM
Oldsmaniac's Avatar
If it were me the first thing I would do was add an extra quart of oil and see what happens.....maybe oil pump pickup is too high on pump.
Old Apr 7, 2009 | 02:49 PM
I already ordered from Mondello a new 7 Qt oil pan, new hig volume hig pressure oil pump, and new pick-up. Im going to have it here in Guatemala like in 12 more days.
do you think the 7 Qt pan is enough?
Alex
Old Apr 8, 2009 | 01:03 PM
Oldsmaniac's Avatar
A 7 quart pan should be more than enough if all is well.....have you tried using a different oil gauge and not so long distance from the engine to the gauge? Is the oil gauge a good quality gauge? Sometimes simple things fix seemingly big problems.
Old Apr 14, 2009 | 05:10 AM
Steve O's Avatar
When you take the pan off check the bearings. Your clearance is set WAY too tight... It should be .003-.0035 on the mains and .0025-.003 on the rods.
I just had one built with .004/.003 and it runs great with a shimmed HV pump, System 1 filter, Valvoline VR1 20W50 race oil, and 6 1/2 Qts in an 8 Qt pan.
Hot oil pressure is 25 psi at idle and 50 at speed
Old Apr 14, 2009 | 01:18 PM
I already check my main # 4 bearing. look very smooth with no damage. im going to attach some pictures.
I have a question if im using to tight clearances what oil should I use?? im using now 15w 40
Old May 4, 2009 | 10:56 AM
sledge1545's Avatar
Check the galley plugs
thanks
Alex
Old May 4, 2009 | 11:26 AM
Smile Good pressure now
Hi, After all this problems I think I have a good oil pressure again.
What I do to solve the problem is: After Talking to Andy Miller from Oldsmobile Performance Products www.oldsperformanceproducts.com, he recommend the following:
1. I install a new blueprint High volume High Pressure oil pump with a new pick-up
2. I install a new 7 Qt oil pan (I put 6.5 Qts of 15W 40, because of my tight clearances)
3. He told me to change my Fram oil filter for a WIX oil filter. And told me to never use Fram Filters
I buy all the parts from oldsperformanceproducts, they are cheaper than Mondello.
After all this changes now Im having when engine is cold like 55 oil pressure, and when the car is like 200 grades I have 40 psi in Iddle.
I still having a little problem. the first time when I start my engine again with all this new parts, I see a lot of air bubbles in the oil. so I contact Andy Again and he told me that, because Im using ARP main bolts, the oil pump is not sitting good in its place, I have to shim a little bit the oil pump housing. that is the only thing I have to do but I never do that before, so If anyone can give my and advice of what exactly I need to do in the pump I will apreciate thanks
Alex
Old May 10, 2009 | 05:04 PM
footbrake's Avatar
oil pump
It sure sounds like the pick-up is not positioned right. I had the same problem once and found the pickup actually fell off.
craftsmen22
Drivetrain/Differentials
Jul 30, 2014 05:47 AM
Railguy
Apr 22, 2014 11:55 PM
HO73
May 19, 2012 06:07 PM
redvettemike
May 25, 2009 08:42 PM
442 Guatemala
Jan 27, 2009 10:12 PM
