Loose choke cap
Old Jul 17, 2022 | 04:17 PM
72455's Avatar
1972 U code Supreme
Loose choke cap
Hey all I've been spending the last few days trying to adjust the automatic choke on my Holley 770 Street Avenger on my '72 U code Supreme, and for some reason, once I set it, the cap will "sping" forward a bit and rhrow my adjustment off ever so slightly. I can get it to about 1/8" gap between the choke plate and the horn, but no matter how far I dual it back to close it up a bit more, the cap won't tighten up and keep my adjustment
Any iseas?
Old Jul 17, 2022 | 07:16 PM
Take the cap off and make sure that all the parts are aligned correctly.
Old Jul 17, 2022 | 07:19 PM
gs72's Avatar
72Cutlass S
There is usually a gasket between the cap and housing. If it is missing you will not get the tension on the cap to hold it in place.
Old Jul 17, 2022 | 07:27 PM
72455's Avatar
1972 U code Supreme
I've done that and double checked.
Old Jul 17, 2022 | 07:36 PM
72455's Avatar
1972 U code Supreme
Hmmm...I don't remember seeing one when I removed the cap to check the alignment of the choke rod tang and the spring. The weird thing is, the cap was tight before I started making adjustments. Is it possible to just make a gasket for the cap?
Old Jul 17, 2022 | 09:03 PM
Should be able to get a $2.00 gasket which is removable (multiple times) and fits per OE specification at your local auto parts store. You may have (originally) had two gaskets - a felt type gasket between the thermostat housing and choke cap and another gasket which sits on the perimeter of the choke thermostat housing - not completely sure if a 770 Avenger has one or both or which type.
Old Jul 17, 2022 | 09:21 PM
edzolz's Avatar
If most of us are like me, we have a box full of extra gaskets and seals left over from older sets. If you don't get one, I will mail you one if you will PM me a snail address.
Old Jul 18, 2022 | 01:57 AM
72455's Avatar
1972 U code Supreme
PM sent
Old Jul 18, 2022 | 05:37 PM
72455's Avatar
1972 U code Supreme
Figured it out...apparently when I took the cap off I somehow reversed the metal retaining ring so it was not making contact with the choke cap "pointer" I switched it around and voila! Choke cap is good n snug now😀 Thanks to all for the suggestions.
Old Jul 18, 2022 | 05:53 PM
Figured it out...cap is good n snug now😀
Old Jul 19, 2022 | 04:35 PM
gs72's Avatar
72Cutlass S
Nice
g77rvd
Mar 26, 2011 02:55 AM
1969w3155
Sep 5, 2010 03:16 PM
ELECMAN
Apr 28, 2010 08:16 PM
1973olds98
Aug 26, 2009 12:54 PM
D Appeldorn
Jun 14, 2008 11:47 PM
