lifter resurfacing?
Old Nov 27, 2016 | 06:10 PM
steverw's Avatar
lifter resurfacing?
Im thinking about having my original GM 0.921 lifters resurfaced? Anyone ever done this. Im hearing a lifter tap that i didnt hear before, havnt really checked it out yet. I dont hear any rocker noise, im just not sure about 0.921 lifters as no GM's are available. I got them from Cutlassefi Mark, i think their Johnson Hi lift. I will check directly with Mark about this also.
Steve
Old Nov 27, 2016 | 06:25 PM
bw1339's Avatar
Lifters are nitrided, typically a few thousands deep. If you surface them, you will likely lose that hard layer.
Old Nov 28, 2016 | 04:51 AM
There are companies that perform this service. How long have those lifters been in the car?
Old Nov 28, 2016 | 12:28 PM
android 211's Avatar
Schneider Cams resurfaces lifters for $5 each as I recall. I found it online. I have a set of good lifters acquired in a parts swap but there is some specks of rest on the faces. Can't use them that way.
Old Nov 28, 2016 | 01:55 PM
lemoldsnut's Avatar
Maybe I'm missing something but, why not replace them with new ones? I know the .921 lifters were hard to get a while back but they are available now.
Old Nov 28, 2016 | 05:00 PM
george landis's Avatar
.921 lifters
Most are $300 a set which is $18.75 each. Chinese ones are little cheaper ($250)but darn questionable. Nos are far and few between. Believe cutlassefi sells them. Johnson-topline hylift are back to macking them? .842 cheap as sbc stuff. When re-surfaced would think they'd be re-hardened. Have heard of 3 or 4 places that were supposed to redo them.
Old Nov 28, 2016 | 05:02 PM
lemoldsnut's Avatar
ended up using Egge in my last engine after a bad set which caused oiling issues but the new ones worked great!!
Old Nov 28, 2016 | 05:17 PM
steverw's Avatar
The lifters in my motor are new...ish. I built it a couple of years ago, just havnt driven it yet. Started it the other day and had what sounds like a stuck lifter that i didnt hear before. I havent really investigated it yet but will soon. I think they are the Johnson lifters, i bought from Mark a couple of years ago. Cam lifters and springs. Other wise the motor sounds great, bottom end sounds quiet, great oil pressure, and it will warm up and idle at 180 degrees all day. Throttle is very responsive. I just hope its nothing major. I did talk to Mark "cutlassefi" today.
Old May 18, 2020 | 04:11 PM
stlregal's Avatar
Sheesh, I wish I would had sen this thread before I bought......I'm going to send all the parts back.... Anyone know where I can by good parts?
Old May 18, 2020 | 04:48 PM
70cutty's Avatar
Beer Connoisseur
PM Mark aka CutlassEFI. Great guy to deal with.
Old May 18, 2020 | 08:09 PM
Charlie Jones's Avatar
Phantom Phixer
Originally Posted by steverw
The lifters in my motor are new...ish. I built it a couple of years ago, just havnt driven it yet. Started it the other day and had what sounds like a stuck lifter that i didnt hear before. I havent really investigated it yet but will soon. .
I don't understand how you think that re-surfacing lifters would help with a noisy lifter .
Lifter re-surfacing is done ONLY in conjunction with a new or re-ground camshaft . You are re-surfacing the bottom of the lifter where it contacts the cam .
Lifter noise is caused by the inner plunger sticking inside the lifter body .
Are you sure that the noise you hear really IS a lifter ? A lot of times , things like bad fuel pump rods , loose timing chains , leaking exhaust header or manifolds , etc, will sound like a bad lifter .
Make sure it is a lifter , and which one it is , before deciding what to do .
If it is a lifter , they can be replaced one at a time . But be sure to follow camshaft break in procedures when using a new lifter on a used cam .
cdrod
Jun 9, 2021 03:07 PM
84oldshurst
Mar 25, 2019 03:55 PM
Macadoo
Jan 26, 2015 04:41 PM
hurst68olds
Feb 24, 2014 12:14 PM
cdrod
Jun 12, 2013 05:31 AM
