Larger valves for c heads
Old Nov 5, 2024 | 11:43 AM
young olds's Avatar
I dropped some ported c heads off at a shop to get cut and a fresh valve job. He said the seats are to far gone but he thinks he can save them going with a slightly larger valve. Wondering what my options are for valves larger than factory large valve. I’m sure the typical 1.7 exhaust will work but what are my options for intake valves, hoping to find stock diameter/length stem with larger head.
Old Nov 5, 2024 | 04:48 PM
cutlassefi's Avatar
2.125’s will normally go in with no difficulty.
Old Nov 5, 2024 | 05:18 PM
young olds's Avatar
Vendor?
Old Nov 6, 2024 | 08:45 AM
young olds's Avatar
I can not find anything beyond this
https://oldsperformanceproducts.com/...stainless-100/
and this
https://www.rpmrons.com/SIvalvescs_olds.html
I don’t have confidence in ordering from either source.
Old Nov 6, 2024 | 02:20 PM
67OAI's Avatar
Old(s)GuysRule
Keep in mind that a 2.125" intake can only be used with a stock size exhaust valve in iron heads and even then it would be marginal due to the loss of material between the valves. You could cut those 2.125" intakes down to 2.110" which would be safer next to the stock exhaust. Also, most of those replacement race type valves have 0.3415" stem diameter (Chev. and Ford small block size) so you end up with sloppy valve stem to valve guide clearance which is only corrected by new valve guides! Good luck!
Old Nov 6, 2024 | 02:35 PM
cutlassefi's Avatar
Hmm not entirely true.
The new Edelbrocks have 2.150/1.68’s with room to spare. If you do the math it’s the same. Knowlton does all their heads with 2.170 intakes.
2.125’s will fit with either 1.68’s or 1.71’s, although there’s no real performance reason to go to the 1.71’s.
And 11/32 is 11/32, it really depends on the manufacturer as to how they decide to machine the stems. Some build in extra clearance, some don’t.
Old Nov 6, 2024 | 03:12 PM
young olds's Avatar
So a 2.125 and 1.68 is a good combo? I’ll have to ask if a 1.68 will be enough or if the machinist thinks I need a 1.7 to get a good seat.
Old Nov 6, 2024 | 03:15 PM
young olds's Avatar
do you have a recommended manufacturer?
Old Nov 6, 2024 | 04:33 PM
MGBill's Avatar
C heads
If the valve seats are gone why not just buy a different set of C heads. (They are plentiful and cheap) If not going for matching engine there are other good Oldsmobile heads you could use to.
Old Nov 6, 2024 | 04:55 PM
young olds's Avatar
I don’t have any money in them currently and they are already ported and filled, I’m willing to spend some money on them if it doesn’t get out of hand.
Old Nov 7, 2024 | 11:55 AM
brownbomber77's Avatar
Speedmaster valves are 2.07/1.68 and they're like, $100 on eBay.
Ferrea is 2.075 and 1.711, eBay has 'em for $250.
Old Nov 7, 2024 | 01:15 PM
young olds's Avatar
Thanks for the reply. My current valves are 2.07/1.625, I’m not sure a 2.075 will be enough.
Old Nov 7, 2024 | 03:09 PM
cutlassefi's Avatar
SI, I’m a dealer for them as well.
Old Dec 29, 2024 | 05:55 PM
young olds's Avatar
I picked up my heads the other day. With the valves out it looks like the seats overlap but the shop owner said he got them all to seal. With both valves installed they appear to have plenty of clearance from each other.
these are 2.125 intake 1.68 exhaust
Tom Canfield
Nov 24, 2023 12:29 AM
1970_442
Aug 11, 2018 07:50 AM
VI Cutty
Apr 30, 2015 02:59 PM
Danp76
Jun 25, 2013 01:55 PM
Hawk1061
Apr 2, 2013 06:44 PM
