Kickdown switch bracket for Performer-Qjet
Old Sep 30, 2013 | 02:46 PM
1BAD71455's Avatar
Question Kickdown switch bracket for Performer-Qjet
I am trying to hook up my b&m kick down switch for the Turbo 400 and would like to know if anyone has been able to purchase an aftermarket bracket for this situation. 455 with performer manifold and quadrajet carb. A 350 used to live in this car and it was switched to 455 and Th400 over 25 years ago. The throttle spring bracket is bolted in the one hole rear of the carb linkage. I cannot find hardly any pictures or parts for this setup. My throttle cable is held on by a bracket off the carb mount area. Thanks
Old Sep 30, 2013 | 03:27 PM
A turbo 350 cable bracket can be modified to work or an L bracket fabricated to mount the switch.
Old Oct 3, 2013 | 03:11 PM
1BAD71455's Avatar
Thanks man, I used an L bracket and success was achieved 1 am. Tested this morning and it worked first time at 60. So did the wildest. Ha ha funny moment.
Old Oct 3, 2013 | 03:12 PM
1BAD71455's Avatar
I meant wipers. Will fix wiring tonight.
Old Oct 3, 2013 | 03:20 PM
Glad it worked out for you. Post a pick of what you did for others to follow.
billmerbach
Nov 9, 2014 03:42 PM
pfergy600
Aug 9, 2014 07:13 AM
68s350
Oct 28, 2013 12:12 PM
Charles Ludwick
Dec 28, 2011 07:04 PM
rocketscientist
Apr 2, 2011 11:54 AM
