Junkyard serpentine?
Old Jun 30, 2021 | 12:04 PM
Jhucks03's Avatar
Anyone scrounged together a serpentine setup for the BBO from junkyard parts?
Old Jun 30, 2021 | 09:15 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Extreme Supreme and Pacific G body has brackets to adapt sbc truck serpentine brackets to the SBO and BBO. The bottom triangle on the passenger bracket needs trimmed or completely removed and is very tight on my Olds 350 for a mechanical fuel pump. There may be more room on a 455 for this. Otherwise they work well and hold everything secure to the block and heads.
Old Jul 1, 2021 | 07:49 AM
Jhucks03's Avatar
That’s perfect! What’s the alternator application, am
i reading it correctly to think it’s converting to an internally regulated alternator at the same time?
Old Jul 1, 2021 | 01:01 PM
Yes, they use the CS130 alternator and the power steering lines are interchangeable if the back fitting is changed in the pump to match the line.
Old Jul 1, 2021 | 01:41 PM
Jhucks03's Avatar
Alternator and P/S pump need to come from the S-10 donor?
I’ll have to hit the ‘yard this weekend.
Old Jul 1, 2021 | 02:52 PM
I believe the 4.3 V6 S-10 stuff will work. Mine came off my 94 Z71 full size, pre 96 for them.
kern84
Hurst/Olds
Dec 9, 2010 09:16 AM
Old Gator
Aug 15, 2010 09:02 AM
doc93
Mar 25, 2010 04:41 PM
72Cut-L-ass
May 24, 2009 07:52 PM
GoldOlds
Jun 11, 2007 04:21 PM
