Istalling bbo
Old May 15, 2015 | 06:09 PM
johnnyjaws's Avatar
Istalling bbo
Im replaceing my sbo with a bbo .What motor mounts do I use solid steel ones or rubber also do I have to move the mounts on the body its a 1970 cutlass s . Also its a automatic 350 thanks for all replys. Could u tell me were to buy them from.
Old May 15, 2015 | 06:31 PM
70cutty's Avatar
Beer Connoisseur
You should use the mounts as if you are putting the small block back in. No need to move anything and use the small block mounts. As far as the solid mounts, I think it depends how much power are you putting out and what are you doing with the car.
I run solid on driver side and rubber on passenger.
Old May 15, 2015 | 06:38 PM
Not a big fan of the Search function, are you?
https://classicoldsmobile.com/forums...tion-list.html
Old May 16, 2015 | 03:53 PM
johnnyjaws's Avatar
Thank you very much.
GoldOlds
Jul 15, 2007 07:34 PM
GoldOlds
Jun 11, 2007 04:21 PM
ooohhha442
May 24, 2007 10:34 AM
Crankit
Jan 25, 2007 05:09 PM
VegasDelta
Feb 21, 2006 04:42 PM
