Iron vs aluminum intake weights
Old Mar 17, 2015 | 02:01 PM
Oldsragger's Avatar
Took a weight test today of both my intake, Iron is about 29kilos and the edelbrock 2151 is 10kilos, what a diffrent.
Old Mar 17, 2015 | 04:15 PM
And how is this a surprise? Iron vs Aluminum is obviously lighter than Iron when it comes to weight. Sorry.
Old Mar 17, 2015 | 04:26 PM
Macadoo's Avatar
Originally Posted by Allan R
And how is this a surprise? Iron vs Aluminum is a no brainer when it comes to weight. Sorry.
True. But sometimes it's worth measuring
Old Mar 17, 2015 | 04:29 PM
Only time it's worth measuring is when you have to install one. If it's iron, call Arnold. If it's aluminum call your wife.
Yeah, I know. It's a comparison thing, but honestly - did you think they were going to be even close?
Old Mar 17, 2015 | 05:48 PM
z11375ss's Avatar
Senior Moment Member
So, like you've never tried this to see how much weight you're saving? You're a liar if you say you didn't. I love this kind of confirmation stuff. You know you are doing a good thing but need confirmation on it. The scale thing is a great way to do it. Try a set of heads next! Nice going Ragger!
Old Mar 17, 2015 | 07:18 PM
Weight is one thing, I'll admit that. But also most of the stock intakes aren't as well set up for flow as the new aluminum ones are. That's the other key factor in this. No name calling please because I really never did that with an intake to compare. I didn't need it to know there's a sizable difference.
Heads would also be an interesting comparison I guess. I'm NOT criticizing Oldsragger doing this, I'm just stating that the difference in weight is fairly obvious. The stats he's generating for you are cool too if you want them.
The only thing I truly measured for weight was comparing a stock GM bumper to a repro cutout bumper for Wmachine (Kurt). They were close to identical and the only reason I did that was because he asked if I would.
Weighing parts isn't something I waste a lot of time on.
Old Mar 17, 2015 | 09:23 PM
So 64 pounds vs. 22 pounds for the metrically challenged. That is a nice weight savings. As said above, it would be interesting to see the difference between iron heads and aluminum heads.
Old Mar 17, 2015 | 11:21 PM
Oldsragger's Avatar
Not really, but its fun to compare weights from orginal to aftermarket parts somethimes, maybe next time i will compare sbo and bbo weight, if the weight will not blow,lol
Old Mar 18, 2015 | 05:16 AM
Macadoo's Avatar
X2
You're going to stand on your scale holding a big block Olds? This I gotta' see
Old Mar 18, 2015 | 06:47 AM
TripDeuces's Avatar
Just weighed my iron bare 'C' head at 51 pounds and my aluminum bare casting at 26 pounds. That's substantial weight off the front end, 50 pounds in heads alone.
Old Mar 18, 2015 | 09:34 AM
Oldsragger's Avatar
Originally Posted by Macadoo
X2
Well im not yet there to deadlift the weight of a bbo,but maybe soon.
I have a engine lifter tool, and its possible to balance a engine on the sides on it and it can will stay on its place, but the weight scale, i think i would need a solid weight if so.
Old Mar 18, 2015 | 09:58 AM
Even more of a no-brainer when you realize that the density of cast iron is 0.252 lb/in^3 and density of aluminum is 0.097 lb/in^3. That's a little less than 3:1.
Old Mar 18, 2015 | 10:06 AM
Oldsragger's Avatar
So im a no-brainer? Ok thank you. point was to Just show the weight diffrent only, or it could be another engine part if i had it aviable. Of course Iron is heavyer than aluminum, but somethimes its fun to see the number diffrents. (in my opinion)
Old Mar 18, 2015 | 10:43 AM
firefrost gold's Avatar
Mine was 75 pounds almost to the 1oth loaded (dirty) E heads and cast iron intake vs new edelbrock heads and a o4b intake
Old Mar 18, 2015 | 11:17 AM
pmathews's Avatar
Enjoyed the info, thanks Oldsragger for posting. I was thinking about a swap to alumimum, and I was wondering the same thing since I'll be buying front coil springs, too.
Old Mar 18, 2015 | 11:36 AM
rollerball's Avatar
Wow, so you lose 45 kilograms by swapping heads and intake to aluminum? Now the last thing we need to know is how much weight can be saved
by swapping the iron exhaust manifolds for headers because intake/heads/headers is what most people swap if they want some power…maybe another 30 kilograms? That would add up to 75 kilograms which is the weight of a smaller adult…something you would definitely feel in the acceleration...
Old Mar 18, 2015 | 11:56 AM
frankr442's Avatar
Lets substitute the word "obvious" for "no-brainer". I'm sure it wasn't intended, but it does sound insulting. I found the original post interesting. I weighed my W30 intake vs cast iron also, 25 years ago, don't remember the numbers.
Old Mar 18, 2015 | 11:58 AM
Aluminum parts aren't always lighter than iron or steel. What most people don't realize is that the specific stiffness for aluminum and steel are the same - steel is three times stiffer that aluminum and has three times the density. For an optimized design in each, the differences in weight will be negligible.
Also, when you get to high-strength steels and aviation-grade aluminum alloys, the strength-to-weight ratios are also about the same, so again for an optimized design they should both weigh about the same. This is why I'm skeptical of Ford's weight savings claims on the new F-150. Apparently, the savings in real life aren't nearly the 700 lbs that the original articles claim.
Aluminum is lighter when the part being manufactured has minimum wall thicknesses that don't allow an optimized design, such as the intake manifold in the original post.
Good idea. I'll go back and change my wording. It wasn't intended to be insulting. Your word choice is the 'obvious' solution to this situation
Old Mar 18, 2015 | 12:03 PM
In the aerospace industry, the term "no-brainer" is simply slang that is synonymous with "obvious" and is not intended to be insulting. Unfortunately, that's a U.S. thing that probably doesn't translate well. Sorry about that.
Old Mar 18, 2015 | 12:29 PM
x2
oldsragger - no insults were intended. The term is a north american colloquialism probably like some of the ones you use in your country to describe some things. Hope all is good.
Old Mar 18, 2015 | 12:39 PM
Oldsragger's Avatar
Dont worry, my english understanding can be a little misunderstand or slow somethimes, it's still interesting to read and learn
I will weight the orginal exhaust manifolds too,but later, but they are from a SBO, im not sure if BBO manifolds are diffrent.
Compare to some headers i have.
Old Mar 18, 2015 | 02:52 PM
costpenn's Avatar
The first time I ever had trouble with my lower back was trying to install a iron BBO manifold with the engine in the car. (I was 24 at the time). Still hurts just to think about it.
Old Mar 18, 2015 | 03:20 PM
76olds's Avatar
Hookers under Hood
Great thread oldsragger, I'm always looking to drop a few pound off my 76 cutlass supreme. I didn't weigh the parts I removed, didn't notice much difference with the headers over the manifolds (SBO) handling them. It would be good to know. I noticed a big difference when swapping out the factory starter to the powermaster mini starter . Also going with the miloden aluminum water pump. I'll be swapping my 3 row copper rad out for a 2 row aluminium which should help just with coolant weight alone. Geez I had factory aluminium rear brake drums and wiring in my 1978 monte carlo imagine that.
Hope this thread keeps going with weight saving parts.
Cheers
Eric
Old Mar 18, 2015 | 03:45 PM
therobski's Avatar
My 67-455 was built with a Torker, Edelbrock heads, Hooker headers, and an aluminum radiator. Besides to the power gains from the loss of weight and the highly modified engine, I feel that my biggest gain was in keeping the beast running on the cool side.I understand aluminum dissipates heat much faster and with the Suburban aluminum radiator that I choose, a Mr Gasket adjustable thermostat the engine runs between 155-175 degrees. It will run 180-190 tops in 100 degree Texas heat in traffic. I believe the other bonus running cool is I manage to get 36 degrees total advance timing on 93 octane with 10.5 compression no pings at all.
Old Mar 18, 2015 | 05:09 PM
Macadoo's Avatar
I'm gonna' need a couple Ibuprofen after reading this post. Dude!
Old Mar 18, 2015 | 07:09 PM
z11375ss's Avatar
My apologies. I just thought you were treating the OP harshly. My fault.
Old May 17, 2022 | 01:31 PM
Burd's Avatar
What if it’s warped. I put an edelgarbage on my car, I started with a new one.
Old May 17, 2022 | 04:46 PM
Cossack's Avatar
66 cutlass
Thanks for posting that. Just bought an Olds with a 455 and aluminum intake and was wondering the weight difference.
jensenracing77
Sep 5, 2014 12:51 PM
dynamic63
Apr 23, 2014 08:43 PM
cutlassefi
Nov 12, 2013 09:51 AM
joepenoso
Nov 23, 2011 01:13 PM
RATCHETMASTER
Oct 29, 2011 06:27 PM
