interchangable parts
Distributor, exhaust manifolds, water neck, oil pump, oil pump drive shaft?, some oil pans, starter?, carb, valve covers, front timing cover, some water pumps.
I'm sure there are more and others will chime in
You may not be aware of this, but there is a tech site on the header bar that will give you a lot of information that you are asking for in your posts. Take a look, another option is to do a search for previous posts that cover the question you are asking. Good luck!
Les
