intakes
intakes
what intakes have clearance for a gm hei distributor ?
i found a offenhouser torker manifold and the seller says the vacuum advance hits the back and has no room to turn, any suggestions would be helpful
I have a Performer on my 64-F85 with a 67 400E, and had a Torker on the 67 442 I sold last year both with an HEI and had no clearance issues.These are made by Edelbrock. Like Mark asked, is it a Offenhouser? Then, I have no clue.
This is a Torker:
This is a typical Offenhauser single plane Olds intake. Note that Offy makes several similar intakes. All have the same large rectangular plenum and short flat runners that are not optimum for most uses. Personally I am unimpressed by Offy intakes. The E-brock intakes are like headers, the Offy intakes are like factory exhaust manifolds.
thanks joe for the input . i found a edelbrock torker manifold for a quadret on craigslist ,your picture shows the back of the torker is flat. it looks like the hei has more clearance than the offi what do you think? the torker i found has one oval hole on each side of carb . what are they for? he has them both capped. the one you pictured has only one on the rt side
B.O.P. Connection
October 29th, 2004 11:34 PM
