intakes
Old Mar 12, 2018 | 04:08 PM
doggonn's Avatar
intakes
what intakes have clearance for a gm hei distributor ?
i found a offenhouser torker manifold and the seller says the vacuum advance hits the back and has no room to turn, any suggestions would be helpful
Old Mar 12, 2018 | 04:48 PM
cutlassefi's Avatar
Is it an Offenhauser or is it a Torker? Offy doesn’t make the Torker.
Old Mar 12, 2018 | 05:22 PM
therobski's Avatar
I have a Performer on my 64-F85 with a 67 400E, and had a Torker on the 67 442 I sold last year both with an HEI and had no clearance issues.These are made by Edelbrock. Like Mark asked, is it a Offenhouser? Then, I have no clue.
Old Mar 12, 2018 | 05:30 PM
doggonn's Avatar
all i know is he claims it is a ten year old offenhouser torker manifold for a 455. i will try to get a part no,
Old Mar 13, 2018 | 06:52 AM
Then the seller has no idea what he really has. Again. EDELBROCK makes the Torker. Offenhauser makes different manifolds. Their flat single plane designs are less than optimum. Don't get a part number, get a photo.
This is a Torker:
This is a typical Offenhauser single plane Olds intake. Note that Offy makes several similar intakes. All have the same large rectangular plenum and short flat runners that are not optimum for most uses. Personally I am unimpressed by Offy intakes. The E-brock intakes are like headers, the Offy intakes are like factory exhaust manifolds.
Old Mar 13, 2018 | 07:16 AM
doggonn's Avatar
thanks joe for the input . i found a edelbrock torker manifold for a quadret on craigslist ,your picture shows the back of the torker is flat. it looks like the hei has more clearance than the offi what do you think? the torker i found has one oval hole on each side of carb . what are they for? he has them both capped. the one you pictured has only one on the rt side
Old Mar 13, 2018 | 07:19 AM
The hole on the passenger side is for the 1970-up hot air choke stove. The oval hole on the driver side would be for EGR. I doubt that the Offy will clear an HEI.
Old Mar 14, 2018 | 05:35 AM
brownbomber77's Avatar
Offy does NOT clear HEI....
joe_padavano
Tech Editor's Desk
Nov 5, 2009 05:08 PM
72 Supreme
Jul 17, 2008 03:42 PM
65 starfire
May 30, 2008 06:51 AM
B.O.P. Connection
Oct 29, 2004 11:34 PM
