Intake gaskets
Old Feb 6, 2015 | 06:59 PM
foreverolds's Avatar
Intake gaskets
The last time I had my 455 apart I used Fel Pro gaskets that were a replacement for the metal valley pan set up.
My intake is leaking and need to replace the gaskets but can only find the valley pan gasket not the other type.
Does anyone know if they are still being made and where they might be available.
Thanks for any help you can give me
Jim
Old Feb 7, 2015 | 06:19 AM
cutlassefi's Avatar
Go to your local AutoZone or Advance Auto and order a Mr. Gasket #404. Use that along with silicone sealer on the end rails and you'll be fine.
Jmo.
Old Feb 7, 2015 | 08:26 AM
Thanks for your help. You jogged my memory, it was Mr. Gasket that I had previously used not Fel Pro. This time I will make sure to reference that part # so I don't have to bother you again.
Today is a good day to start this project
Again thanks much
Jim
Stevec
Mar 15, 2012 01:19 PM
don_69sbo
Sep 5, 2011 01:35 PM
jag1886
Jan 16, 2011 08:41 AM
rtpassini
Nov 20, 2010 05:58 AM
Kidcutty
Mar 25, 2010 09:29 PM
