Intake/Cam compatibility question
Old Jun 13, 2011 | 07:41 PM
Bill in NC's Avatar
Hey guys I've been fighting a drivability problem during hot start-ups which caused me to pull the intake looking for vacuum leaks. I found five. And the front two cylinders and rear two cylinders were starting to suck coolant past the gaskets. I know this Torker intake has been cut to compensate for the heads and block being milled, but by lookiong at the marks left on the intake and seing how the gaskets split, warped, and pulled away from the surfaces, I can tell it was cut too far. This is not surprising to me after seeing this machine shop doing some pretty nasty work in the past. It is sitting too low, and is not close enough to the cylinder heads to seal and clamp the gaskets properly. I have a Performer intake I can put on it, but I'm not real sure how well it will work with the Comp 292h (part# 42-236-4)? Is any one running the Performer w/ the 292h? This is a 95% street car that may make 2 TNT trips a year. Here is just a couple of quick pics. Thanks for any input guys. I'm learning the way of the Olds big block, so please bear with me on the silly newbe questions that you hear often.
Old Jun 14, 2011 | 04:42 AM
cutlassefi's Avatar
Use the Performer but cut down the center divider about a half inch and slope it towards the deep side.
I used one on a 455 with a 238/246 Hyd Roller, ran great, made 500lbft of torque at just over 3800rpm.
Old Jun 14, 2011 | 06:54 AM
dc2x4drvr's Avatar
Hmmm,I discovered the same breaks in my Fel Pro p/n 1356 performance intake gaskets when I took my Torker off to put on a 04B. Try a different brand of intake gasket, I used SCE.
Old Jun 14, 2011 | 12:06 PM
cutlassefi's Avatar
Mr. Gasket #404.
Old Jun 14, 2011 | 03:08 PM
Bill in NC's Avatar
Is the SCE or Mr.Gasket brand gaskets set that you guys used any thicker than the Fel-Pro?
shepo1
Nov 24, 2014 06:45 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
455Gbody
Aug 4, 2009 07:19 PM
delta881972
Aug 25, 2008 02:12 PM
D. McHenry
May 5, 2006 03:23 PM
