Installing new oil pump
It has been a long winter and I am finally reassembling my 67 400 from my 442 after getting it back from the machine shop. It has been sitting on my stand for 4 months now just waiting for reassembly. This may sound stupid, but is there a gasket between the oil pump and block? I just want too make sure. I do not plan on pulling this out again....
If you are using ARP studs, the base of the pump will not sit flush to the block.
You will need to grind some material off.
If it is a stock pump, be sure to braze the pick up to the body.
If it is an aftermarket pump, use Loctite on the bolts, and inspect the welding around the pick up carefully.
A Milodon pick up with a faulty weld cost me a $6,000 motor.
SCHUMANNS DYNAMIC PERFORMANCE SSI60700 COPPER OILPUMP GASKET 5 PACK OLDS V8 350 425 455 $15.95 Copper Oil Pump Gaskets
cobalt
January 15th, 2016 11:50 PM
motorhead_1
May 15th, 2015 06:59 PM
stlbluesbrother
March 21st, 2011 03:24 PM
