I see torque in my future
Old Jun 20, 2008 | 10:24 AM
gearheads78's Avatar
car guy
I was in the right place at the right time this week. I was able to pick up a really nice std bore 455 F block and a 10/10 4speed crank for pennies on the dollar. 8)
Old Jun 20, 2008 | 10:29 AM
citcapp's Avatar
Now the fun begins, How are you going to build it and what is it going in?
Old Jun 20, 2008 | 10:41 AM
Oh man! Sorry about that crack in the block. You better just send it to me so you don't get too depressed about wasting your money.
Just kidding. Awsome find though. Keep us updated.
Old Jun 20, 2008 | 01:27 PM
car guy
It will go in the 66 I am building. see here Will be a hot street motor 500ish HP in front of the TKO 5 speed.
I have built a few motors but this will be my first Olds. Should be fun
Old Jun 21, 2008 | 10:24 AM
Oldsguy's Avatar
Past Administrator
Lucky dog, lucky dog...
Old Aug 2, 2008 | 07:28 PM
sethj78's Avatar
I just picked up a complete and running 455 F motor. I am wondering if all 455's have that shield bolted in the lifter valley. I seen a pic of a 76 model (my understanding is that f is 1967 to 1971 and fa is 1972 and up) and it had that shield. the pic above also has the shield and it is the same id# as mine. I am going to use the bolt bosses to bolt down a roller lifter retainer. My father drilled and tapped his 403 block for this but he had it to a bare block. Just trying to get some info before i open a good running motor. Thanks!!!
Old Aug 3, 2008 | 06:20 AM
Lady72nRob71's Avatar
No fair!!
Old Aug 3, 2008 | 08:32 AM
citcapp's Avatar
We will all watch with interest as you build you new toy mover. Take lots of good pictures as you have done with your frame off build. Do you plan on a motor that runs on pump gas? How do you figure to get to the 500 hp figure? Good luck and a great buy
Old Aug 3, 2008 | 04:21 PM
car guy
I've already got a set of mild ported Edelbrock heads. Those with a carefully built short block and the right Hydraulic roller should make the power I want.
I just got to keep myself from getting out of hand. The last street combo I built was for a buddies truck. 461 BBC mild ported oval ports 9.0 to one and just a flat tappet cam. With a small YS series Vortec blower 8lbs non intercooled it made 703 HP and runs 6.50's @ 107 miles per hour. Oh by the way thats a 4200 lb truck.
http://www.youtube.com/watch?v=du1GGfF9Xlg&NR=1
http://www.youtube.com/watch?v=jaM7yfOwzc8
Old Aug 3, 2008 | 07:04 PM
citcapp's Avatar
It is easy to get carried away
My 455
bored 40 over with torque plates
keith black 15 cc pistons
Cat "H" rods
8 quart oil pan with windage tray high volumn oil pump
Main line hone with studs rotating assembly balanced
crane roller hyd cam
Crane roller hyd lifters
PRW roller rockers
Edelbrock performer aluminum heads
Edelbrock performer intake
Holly 770 cfm carb
MSD Distributor and coil
This should move my 57 ok I think
442much
Feb 6, 2010 12:44 AM
Jamesbo
Jun 10, 2009 02:46 PM
74 Omega
Vista Cruiser & Wagons
Sep 19, 2008 05:06 PM
