i need advice... please!!! 1964 88 dynamic convertible
Old Apr 14, 2008 | 09:29 PM
convertible's Avatar
i love this car and i found one for sale... I just found out that the engine that is in it is not the original 394 but a 330 2 barrel from a jetfire.. the car is unrestored but solid and not much rust. HOW MUCH IS WORTED??
HOW MUCH WOULD U PAY FOR IT???
plese help me... thanks
Old Apr 14, 2008 | 09:45 PM
59-59-59's Avatar
#1.. Its worth what someone else is willing to pay...#2.. Thats ALOT of work to put a 330 in the place of a 394 - are you positive this is a 330? Why would they put a 330 in place of a 394? Thats taking a couple steps backwards if you ask me. Whoever did this swap had to of made new engine mounts, transmission mounts, and a TON of modifications. Do me a favor and just count how many valve cover bolts there are.. # 3 Since when did Olds make a Jetfire? Do you mean Jetstar or Starfire?
Old Apr 14, 2008 | 10:48 PM
Eddie Hansen's Avatar
Ummmm maybe it's me but.....
convertible..... Dude!!! you are posting so many threads asking sorta the same questions... why don't you kinda stick to one thread so we can all follow the bouncing ball... getting confusing in here, I am sure a lot of folks would like to help but where to post??
now from your first post it seems you got the car
https://classicoldsmobile.com/forums...ows-about.html
then another thread that asks how much would you pay for it??
https://classicoldsmobile.com/forums...ed-advice.html
and same again here
https://classicoldsmobile.com/forums...nvertible.html
Dude..... LOL... I guess you need some info??
why not post a pic or two, this will give the guys some reference point.
and like the guys said, how much is it worth to you?
sorry for this kinda post, but you had me racing all over the forum???
Old Apr 15, 2008 | 06:08 AM
rocketraider's Avatar
Oldsdruid
I'm wondering if this car is a Jetstar 88 that has had a Dynamic front clip put on. Does the dash plate say Dynamic 88 or Jetstar 88?
1962-63 turbocharged Cutlass. Then in 64 marketing started calling 330 engines Jetfire.
Old Apr 15, 2008 | 09:45 AM
Double check that engine. If it is a 330 then like some of the guys said, there were alot of modifications done to the car. However, this could be a good thing depending on what you want to do to the car. A 330 mounts the same way the later Oldsmobile engines do (350, 403, and 455). So, if you want to put a more modern engine and transmission into it half of the work is done.
If the engine has been changed you won't be able to show the car as an "original." You just need to decide what you want in a car. Personally, I would think a 330 would be better than a 394. I have a 394 in my 64 98 and I don't like it very much. I feel that the newer Olds engines are MUCH better.
Old Apr 15, 2008 | 11:17 AM
okk
(Ok first of all sorry if I don't write really well but I'm italian) let me explain to u guys..... i signed a contract for this car... that's why i said it's mine... but the dealership manager filled out papers in the wrong way and we have to do it again!!! ...So the car is not mine yet... yesterday I found online a brochure about 1964 oldsmobile that says that the 1964 olds dynamic convertible came with the 394 260or 280 hp... at the dealership told me that is a 1964 dyn 88 with a 330 2 barrel... the engine is blue(can that help?)
the car is in working and running conditions(top,seats'radio, etc). not much rust and good interiors.
Now... i really do love this car.. but i wanna make sure i'm spending the right money for it.
thanks again
Old Apr 15, 2008 | 12:48 PM
Oldsguy's Avatar
Past Administrator
I don't know about Italian law and your situation specifically enough to be able to help but...If signing the contract means the car is legally yours now then just take delivery and start researching the car's history and drive it and enjoy it. If signing the contract means you can still change your mind then get the Vehicle Identification Number from the dash, the engine code from the engine and any other documentation that you can collect and post it here and we will try to help you decipher it all and then you can make a final decision based on that knowledge. The value of a vehicle is such a subjective item. And we might be making a great mistake stating a value based on our knowledge of the market here in the U.S. compared to the same vehicle's value over in the E.U. About the engines, I think that 1964 was the change-over year when the 394 and the 330 were both available in some models. I do have a reference at home that is fairly accurate, I will check it for you and post tonight.
Old Apr 15, 2008 | 07:53 PM
ok another question..
I'm italian but i live here now..miami beach,fl ...
how do I see if is a matching numbers ? i couldn't find the num on the engine... can somebody tell me where it should be?
thanks
Old Apr 16, 2008 | 05:09 AM
Oldsguy's Avatar
Past Administrator
Oh, sorry my mistake. I should have looked closer at your user name info. Anyway, if it is a 330 engine look on the front of the block just above the timing cover, you should see some number cast into the block on the horizontal surface. Navigate to the tech section using the grey tool bar above, then look to the 1964 - 1990 small block section. It will show you some information on identifying you engine and give you some good information. Good luck.
Old Apr 16, 2008 | 09:01 AM
Question ..more informations...
the block in the car is blue... could it be a 350?? would the 350 fit in my car without too many modifications?
thanks again
Old Apr 16, 2008 | 09:40 AM
Run to Rund's Avatar
You need to get someone who knows Olds in your area to look at the car. A blue engine could be anything, but probably a late 350-403-455. Don't assume the car has any high value meanwhile. It is hard to get parts for them, and they aren't real popular, meaning they don't command much money. Starfires are the most likely to have enhanced value among the full size Olds of the first half of the 60s.
Kyle's 77 Cutlass
Nov 30, 2014 11:42 AM
ghsot
Sep 27, 2014 06:40 PM
greek cutlass
Oct 19, 2011 02:43 PM
convertible
Apr 14, 2008 09:42 PM
rtdoff04
Jan 16, 2007 06:39 PM
