how do I identify the block type of a 425 / 455 ?
Old November 18th, 2007, 03:20 AM
Aussie67Delta88Custom's Avatar
Question how do I identify the block type of a 425 / 455 ?
And are any better than others ?
My engine rebuilder says the first 455 I gave him is stuffed, but before I let him scrap it I thought I had better ask
Gary T
Oldsmobile club of Australia.
Aussie67Delta88Custom is offline
Old November 18th, 2007, 01:25 PM
Past Administrator
Oldsguy's Avatar
Did he say how? Is is not worth repair or not repairable at all? There should be some guys on here that can help you ID an engine if you provide some data for them to go with.
Oldsguy is offline
Old November 18th, 2007, 02:51 PM
Redog's Avatar
If the motor is stock to the car, I don't think it's a 455. I have no info on a 455 before 1968.
But I could tell you what block you have, if you believe it's a 1967. The only info I have on big blocks in 67 are as follows
1966-67 [390925 block]
    1966-67 [389244 block]
      1967 [390925 block w/.375 drill spot]
        1967 [389244 block w/.203 drill spot]
          1967 [389244 block w/.375 drill spot]
            Redog is offline
            Old November 18th, 2007, 09:16 PM
            Junior Member
            88 coupe's Avatar
            And are any better than others ? ........
            Assuming, you are talking about blocks/cranks:
            Unless you are planning a "full on" racing engine, one is as good as the next.
            Norm
            88 coupe is offline
            Delmont 88 PA
            December 16th, 2015 03:37 PM
            L77F85
            Drivetrain/Differentials
            16
            November 29th, 2013 06:19 AM
            fast67vellen2o
            August 12th, 2012 06:53 PM
            hotrodpc
            August 23rd, 2009 10:05 PM
            dar83501
            September 17th, 2007 09:22 AM
            Quick Reply: how do I identify the block type of a 425 / 455 ?
