How do 455 GA heads rate?
I don't know what your goal is w/ your 455, but I found that one gets the most bang f/ their buck using the factory heads, in your case the Ga heads, and along w/ after market valve trane components, having the heads cleaned up and a good valve job done by someone who knows how to do Olds heads. W/ good block work, and w/ a good cam and pistons, and then an intake, carb, headers and ignition, you can get around 425 hp and maybe 500 lb.ft. of torque. Pretty good f/ just bolt-on stuff and machine work. Ofcourse aluminum heads will get you more power, but costing you a bunch more money. If you're thinking $s per hp, the factory heads and bolt-on components is the way to go.
I do have a set of C heads that I'm saving for another build, more radical. This particular engine, I pulled out of a parts car. From every indication the motor was professtionally built in 1992. I pulled a 370 hp W30 cam out of it and put a Lunati Bracket Master 2 in it. I'm sure that it was punched .030 over and the pistons replaced, I'm still researching the pistons. I do have project pics under my account. Mined you, this is a low bucks project and I am a man of limited resources, (money).
Dale
Dale
Dale
Dale
The guy who did the heads for Panos' build, Champion Race Heads, doesn't do many Olds heads but he's very good and does beautiful work.
You're right on the hp and tq though, 425/500 isn't too dificult on a 455.
I disagree. What you need is someone who knows heads period. It doesn't matter what brand they are if they have the knowledge to do whats best for the application.
I would just think twice before I would drop them off at any old machine shop.
I tend to agree with Texas Jim.
JMO
Jim
4door!cutlass
March 24th, 2014 05:41 PM
