How to adjust fast idle on ‘69 Toronado?
Old Dec 5, 2019 | 09:15 PM
Jon442's Avatar
Gearhead
My ‘69 Toronado fires right up, so the choke is working properly. But it doesn’t kick up on fast idle. Can someone show me how to adjust the fast idle?
Old Dec 6, 2019 | 03:19 AM
The fast idle screw is on the passenger side of the carb, on the throttle shaft.
Old Dec 8, 2019 | 10:55 AM
Jon442's Avatar
Gearhead
Here's a photo of my carb.
As I noted, the car will start right up, but not kick up on high idle. After it sits for a few minutes, then it will start to increase idle speed. The idle speed won't kick back down until you drive it. Any ideas?
Old Dec 8, 2019 | 12:15 PM
The normal operation is to depress the gas pedal to set the choke and fast idle on a step of its cam, start the car, then after the choke starts opening any throttle application will drop the fast idle to a lower notch on the cam, which could be an intermediate engagement or fully disengaged, depending upon how far the choke is open.
Old Dec 8, 2019 | 02:41 PM
VC455's Avatar
Barely Registered
As Kenneth noted, these old cars don't manage the rpm automatically...
  • It takes a movement of the accelerator to preset the fast idle before you start a cold engine
  • To drop the fast idle speed once the car starts to warm up, takes a movement of the accelerator
Old Dec 8, 2019 | 06:09 PM
Can you post a video of a cold start? Is the choke pull off functioning? Maybe it’s idling slow on a cold start because it’s loading up. As the choke heater warms up and the choke becomes to open the engine speed would naturally increase. Just a idea.
rustbukt307
Apr 18, 2018 11:41 AM
77ricbaez
Nov 30, 2016 09:54 AM
defiant1
Apr 28, 2014 01:07 PM
radioburningchrome
Mar 8, 2014 02:42 PM
455man
Nov 14, 2013 07:41 AM
