HELP PLEASE
Old Apr 16, 2008 | 12:55 PM
65_Dynamic_88's Avatar
Exclamation HELP PLEASE
does anyone know the correct pushrod legnth for the "ultra high compression" 425? i need to know because i'm doing a bunch of engine stuff to it including new push rods but it's also my daily driver so i dont realy want to pull it all apart just to measure them.
Old Apr 16, 2008 | 05:46 PM
aliensatemybuick's Avatar
"me somebody" site member
Sorry I don't have the info you need, but you could just pull a valve cover, remove one rocker bridge and pull the rod to measure...could probably do it and have it back together in a very short period of time.
Also, depending on exactly what you are doing to the motor, the required pushrod length may change anyway?
Old Apr 17, 2008 | 09:57 AM
Run to Rund's Avatar
according to 1972 gmpd book, 9.625" for 65-6 425. 67-425 is 9-21/32" and 455s are 9-37/64"
Old Apr 19, 2008 | 02:31 AM
yeah but the only problem with that is in order to pull a valve cover i have to remove the brackets from the front of the engine (p/s, alt. etc..) and i'd rather not do that until i'm ready to do everything i'm gonna do to it. i'll still double check after i have it apart, i just wanna get the info before i start pulling stuff off haha
thanks dude, that helps. apreciate the help
aquabird
Oct 2, 2013 10:34 PM
drtdobber
Feb 14, 2007 01:16 PM
Yllwbnna
Cars Wanted
Nov 13, 2006 09:50 AM
70ra455
May 26, 2006 12:30 AM
melsolds69
May 24, 2006 05:58 AM
