Help with identifying Oldsmobile 455
Welcome. That casting number was used for more years than just 1970-72. As Eric points out, the VIN derivative stamp will tell you the exact model year of the BLOCK. Other parts are bolt-on and may or may not be original to that block. The Pontiac blue paint needs to go, also...
Welcome. That casting number was used for more years than just 1970-72. As Eric points out, the VIN derivative stamp will tell you the exact model year of the BLOCK. The second character of the VIN derivative is the model year. For example, 8=1968, 0=1970, etc. Other parts are bolt-on and may or may not be original to that block. The Pontiac blue paint needs to go, also...
Side by side, it almost looks exactly the same as my father's 1976 Pontiac 455.
31M
3 = Olds
_1 = 1971
__M = Michigan [Lansing] car assembly plant
400,000+ VIN tends to indicate a Toronado motor but the intake does not look Toronado. What is the intake casting ID letter in the depression aft of thermostat and/or 6-digit CN aft of carb?
Letter on the corner of the head should be a "G" for 1971 455's
Oil fill tube number should be 1xxxxxx, where x is any digit 0-9. Again the 1 is for 1971 model year.
3 = Olds
_1 = 1971
Actually, I think in 1971, the Lansing-built cars started at 100001 for A-bodies, 400001 for full size, and 700001 for Toros. Don't have my 1971 CSM here at the office, however.
31M
3 = Olds
_1 = 1971
3 = Olds
_1 = 1971
The letter on the intake to the right of the thermostat is "L".
The Rochester carb has a "remanufactured" tin label. It was bought new when the engine was rebuilt and not original.
The car has J heads although I'm not sure if they are original to the car. They were taken apart and rebuilt with aftermarket valves.
The 4xxxxx serial number would suggest it was born in a full size 1971 Olds (Eighty Eight or Ninety Eight). That's really kind of irrelevant, as all 1971 motors had soup-bowl sized dishes in the pistons for 8.5:1 CR. The J heads tell us the engine's been worked on, so you have no idea what else was done to it.
Thank you for all of your help everyone. You guys really know your stuff.
benzur
July 20th, 2015 04:50 AM
