Help with engine ID?
Old Oct 15, 2009 | 05:49 AM
sealw98's Avatar
the code on my 1970 supreme says 35m32191442 the last number 2 sits side ways. the last 6 does not match the last 6 of my vin so I'm assuming the engine has been swapped, but what is this engine out of and what year?
Old Oct 15, 2009 | 06:37 AM
Art Fuller's Avatar
75 oldsmobile
Old Oct 15, 2009 | 07:12 AM
sealw98's Avatar
how do you know this? Can you explain to me how to read the codes.
Old Oct 15, 2009 | 07:41 AM
Art Fuller's Avatar
The 3 stands for Oldsmobile. The 5 stands for the year, 1975. The third is a letter, M, that stands for where it was built. M is Lansing Michigan. I believe the rest of the numbers match numbers in the VIN of the car the motor came from.
If you have a '70 your engine number should start with 30.
Old Oct 15, 2009 | 08:25 AM
sealw98's Avatar
Thanks Art appreciate your help.
Old Oct 15, 2009 | 08:33 AM
The VIN derivative should only be nine characters long, so it appears that someone has added numbers to yours.
nolabigdawg
Nov 16, 2014 06:45 PM
805cut
May 3, 2012 08:11 PM
MJAKS462
Apr 15, 2010 02:34 PM
Olds luvr
Mar 17, 2010 06:57 PM
pinky
Oct 1, 2007 11:24 AM
