Help with Carb ID
Old Mar 20, 2022 | 09:53 AM
TATA455's Avatar
Help with Carb ID
I have a 7042251 Carb. 0532 Date Code. Was trying to identify what cars it was installed on. Appreciate any help.
I know it is a 455 Olds carb. Looking to know exactly what cars it was installed on.
From the Olds Manual - "7042251 codes are UA, UB, US, UT \ engine codes"
What cars were those engine codes used in.
Old Mar 20, 2022 | 09:57 AM
442Harv's Avatar
Auto tran,A,B,C body cars.
Old Mar 20, 2022 | 10:05 AM
oldoldss's Avatar
704 = 1970-1975
2 = 1972
2 = Q-Jet
5 = Oldsmobile
1 = Manual trans
(A quick online search shows it to be for a 455.)
Old Mar 20, 2022 | 10:16 AM
Originally Posted by oldoldss
1 = Manual trans
NOOOOOOOO!
Will this odd = manual, even = automatic myth ever die?
Every single 1972 Olds full size with a 455 came with this '251 carb. Every single one of those also came with a TH400.
Every single 1972 442 with a 455 came with a 7042953 carb, including all U-code automatic cars.
Every single 1972 Olds with a 350 (both AT and MT) came with a 7042250 carb.
Old Mar 20, 2022 | 10:19 AM
TATA455's Avatar
Thanks - That is what I was looking for.
Was the 2253 used on both Auto and 4 Speed cars?
Same with the 2251?
Did a regular 442 get the same carb as a W30?
Is there any info on the Jet and metering rod differences for the 2251 vs 2253?
Old Mar 20, 2022 | 10:30 AM
Both use the same CH secondary metering rods
Both use the same 0.049 primary jets
'251 uses 50B primary metering rods, '253 uses 47B rods
'251 uses a 7036019 power piston spring, '253 uses 7037851
There are differences in the choke housing and thermostat coil, but other than different P/Ns, I can't tell you what the differences are.
Old Mar 20, 2022 | 10:32 AM
Yes, for 1972
v8al
Jan 28, 2022 04:00 PM
NDERISE
Sep 8, 2014 01:50 PM
stonecad
Feb 28, 2014 08:22 PM
Indy_68_S
May 4, 2011 05:56 AM
sx455raidercelticfan
Jun 21, 2010 05:36 PM
