Help with cam/valve spring selection.
Old Oct 23, 2014 | 06:22 PM
timholliday's Avatar
Member
I could use some advice and or suggestions on a motor I am putting together. It is .030 over with "D" heads, cast iron intake, quadrajet carb, WZ exhaust, turbo 400 trans, 3.23 rear, air car. The valve springs were already installed when I purchased the heads. I am looking for a cam to give me similar performance to a stock '69 H/O.
I found a Comp Cam Factory Muscle hydraulic camshaft kit that's states it is a direct replacement for stock GM camshafts. It is listed for a '68 H/O. Any thoughts?
I also need to know if the springs would need to be replaced based on the cam.
Thanks, Tim
Old Oct 23, 2014 | 06:26 PM
Member
Old Oct 24, 2014 | 06:33 PM
cutlassefi's Avatar
If you don't know what part number the springs are then you need to pull a couple off and measure them.
Old Oct 24, 2014 | 08:39 PM
Lars's Avatar
well the 69 HO is like the holy grail around here, SO are you looking for an "original air in the spare tire" type of cam or something that will make that 400 sing? Mark^^^ knows what he's talking about. most cams like a certian seat preasure.
Nickyloves442s
Dec 1, 2014 11:18 PM
lonestarjarhead
Nov 7, 2012 08:40 AM
78cutlass
Sep 11, 2011 05:24 PM
ijasond
May 13, 2008 08:27 AM
bobolds
Mar 26, 2007 02:45 PM
