Help
Old Apr 8, 2014 | 08:16 PM
antweave's Avatar
Help
. I finally got my HEI running in my 455 cutlass after wiring it up to the ignition and running some fusible links to the battery and everything went fine. Went for a test drive even washed the car.put it the garage for the night just fine.next morning went to crank it up and no fire changed the module and condensor and still no fire I am about get me gallon of gas and a match if you know what I mean
Old Apr 8, 2014 | 08:26 PM
Did you check to see if you have voltage at the Batt+ terminal of the distributor, both when the key is on and in the start position? What were the fusible links for?
Old Apr 8, 2014 | 08:36 PM
So why did you want to switch to HEI again?
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
