Help!
Old Jan 13, 2020 | 02:28 PM
Doug Carner's Avatar
69 Ol' Blue
Help!
I just took my 69 Olds 400 block down to the machine shop and they said I needed .30-40 over pistons due to wear. I cannot find oversize pistons anywhere. Anyone know of some options?
Old Jan 13, 2020 | 02:56 PM
OLDSter Ralph's Avatar
PM Cutlassefi
Old Jan 13, 2020 | 03:37 PM
CRUZN 66's Avatar
Olds Fever
Super Cars Unlimited:
https://www.supercarsunlimited.com/Pistons-i105.aspx
Old Jan 13, 2020 | 04:30 PM
You actually need .030" or .040" over pistons (that's 30 or 40 thousandths, not 3 or 4 tenths).
Depending upon what your goals are for this engine, you need to determine if you want forged pistons or cast pistons, and you also need to determine what compression ratio you want. If you merely want cast type factory replacements, Egge Machine has them; if you want forged in a specific compression ratio then likely you will need to custom order them.
https://egge.com/part/egg-1000-l2346-8/
Old Jan 13, 2020 | 04:35 PM
VORTECPRO's Avatar
Egge Machine
Old Jan 14, 2020 | 05:13 PM
BillK's Avatar
If it will clean up at .030" . . . . .
https://www.ebay.com/itm/TRW-L2243-0...kAAOSwpJJeElTy
Old Jan 14, 2020 | 05:39 PM
cutlassefi's Avatar
Wrong piston and description. They didn’t make 400E’s in 68-69. He has a 68-69 400G block. It has a much smaller bore than an E block.
Slight mistake there.
Old Jan 14, 2020 | 06:45 PM
BillK's Avatar
Ok, My screw up 🙂🙂 I was actually trying to make a point that stuff is available with a little searching. I'm almost more curious why his machine shop isn't getting them for him ?? I rarely tell customers to get parts.
Old Jan 14, 2020 | 06:55 PM
I was wondering that when I first read the post as well. Seems the machine shop would be THE place to locate the required parts.
Old Jan 14, 2020 | 07:00 PM
BillK's Avatar
Yes I don't understand some of those guys. I don't make a killing off of the parts but every little bit helps and plus that way I know that they're going to be correct. To be honest with you most of the time I can meet or even beat the online prices and still make a few dollars.
Old Jan 15, 2020 | 01:09 AM
svnt442's Avatar
Makes me think the place doesn't want to do the work.
Old Jan 15, 2020 | 07:39 AM
edzolz's Avatar
Maybe the shop isn't familiar with Olds engines. If so, he should find a shop that has a reputation for building Oldsmobiles.
oldolds88
Jun 8, 2019 09:03 PM
Stefano
Nov 3, 2016 09:46 AM
Olds442toro
Mar 5, 2014 07:26 PM
Oldskool84
Dec 30, 2013 03:50 PM
jag1886
Feb 12, 2011 11:02 AM
