heater hoses routing 455 no A/C
Old May 3, 2024 | 05:14 AM
blp's Avatar
blp
Trying to remember prior to last years 455 install....
The old 350 I think the outlet hose from heat core went into manifold at the rear of said manifold.
The 455 has a port just to the passenger side on top of manifold that is just above the water pump.
My question I guess is it ok to use outlet hose to that front top manifold port?
thanks for the time as usual...much apperciated
Old May 4, 2024 | 04:35 AM
All Olds V8s have the same heater hose ports - the 5/8" outlet TO the heater core located at the rear passenger side of the intake and the 3/4" inlet FROM the heater core on the water pump. A/C cars have the heater control valve screwed into the intake manifold port, non-A/C cars use the nipple with a restrictor in it.
Old Feb 28, 2025 | 01:44 PM
Charlie D's Avatar
Thank you!!
denf221
Jun 29, 2021 10:55 AM
HoldSteady
Aug 22, 2016 06:13 AM
RetroRanger
Aug 20, 2013 11:51 AM
defiant1
Jun 17, 2013 09:36 AM
