heater control valve
Old Oct 26, 2009 | 09:40 PM
1973olds98's Avatar
iam in the process of putting my 455 back together and was wondering what plugs into the heater control valve...Is it some sort of sensor..
Old Oct 27, 2009 | 05:27 AM
Lady72nRob71's Avatar
The heater valve screws into the rear right of the block. The big hose goes to the heater core and the tiny hose inlet on the valve is for the vacuum control hose. That hose would go to the heater controls. I think in 1973, vacuum applied = valve off.
Not sure if this helps, but I hope so...
Old Oct 27, 2009 | 05:29 AM
There is also an electric sensor that goes to the heater control valve. At least in my 71 98 there is. I'm not really sure what it is used for. There is a bung in one side of the valve where the sensor screws into.
Old Oct 27, 2009 | 07:43 AM
Does the car in question have the auto temp controls??
If so, thats a good explanation of an electrical sensor - I never have seen that...
Old Oct 27, 2009 | 07:56 AM
rocketraider's Avatar
Oldsdruid
The threaded port is for a coolant temperature sensor for Comfortron equipped cars. Most all the valves have the port since it was probably cheaper to have one p/n for all applications than different valves for each type of A/C.
Comfortron is designed to not operate until the car has warmed up sufficiently (coolant temp >120 degrees) to provide heat. The water valve sensor does this. Two wires to it, black with double white stripe at passenger rear of engine.
If car does not have Comfortron, the threaded port is not used.
Old Oct 27, 2009 | 08:14 AM
1973olds98's Avatar
ok the sensor part was what i was referring to..Mine does have it..i was just wondering what it was and how it works..
Old Oct 27, 2009 | 10:08 AM
The sensor is a temp sensor that should prevent the blower motor from coming on until the coolant warms up to prevent blowing cold air at the passengers.
Old Oct 27, 2009 | 10:42 AM
My car has the temp sensor. It might not be working properly because my blower no longer works. I was thinking I might have a vacuum leak as well. I need to check it out.
Old Oct 28, 2009 | 03:57 PM
Easy enough to test. Simply pull the connector off the temp sender, jumper across the terminals in the harness connector, and see if the fan runs. Alternately, check continuity at the sender terminals with the engine cold and again with the engine hot.
Old Oct 29, 2009 | 05:43 AM
I'm sorry, I don't understand. You say check continuity at the sender terminals; however, there is only one terminal on the temp sensor that attaches to the heater control valve.
Old Oct 29, 2009 | 05:33 PM
OOPs, sorry, I'm working off the later model cars that use the two-wire sender. In your case, check continuity to ground.
Old Oct 30, 2009 | 04:54 AM
Thanks!
jensenracing77
Mar 19, 2014 04:08 PM
zodiacblueS
Apr 7, 2012 02:38 PM
Mister
May 13, 2011 03:53 PM
blue72regency
Dec 12, 2007 01:12 PM
bjtstarfire
Dec 15, 2006 10:14 AM
