Heat Riser Block Off Plates
Old Apr 23, 2017 | 12:33 AM
STLCRZY's Avatar
Anybody fabricate there own or use Mondos Heat Riser Block Off Plates like :
http://www.ebay.com/itm/Oldsmobile-M...-/222448759620
know it would be better ways to block of , but only want to talk about this way.
anybody?
Old Apr 23, 2017 | 08:36 AM
IMHO, those should only be used with fiber gaskets and it may cause a leak with the steel turkey tray. Some fiber gasket sets come with them.
Old Apr 23, 2017 | 10:04 AM
IMHO, ...
No need to be humble, you are correct.
The thickness and compressibility of the fiber gaskets accommodates the thickness of the steel shims. The stock steel gasket will not.
I also have no idea why one would pay Lynn Wilfringer $35 for these. You can make them for free from scrap you probably have lying around the house. Galvenized steel (not aluminum) flashing comes to mind.
Old Apr 23, 2017 | 11:14 AM
STLCRZY's Avatar
yes i think about make my own,less work than the EDE-Plugs
Old Apr 27, 2017 | 11:24 AM
83hurstguy's Avatar
The only nice part of the Mondo ones is that they have the raised boss to slip into the oval crossover hole on some of the early heads, and stay there while you assemble things.
Old Apr 27, 2017 | 12:55 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
IMO these don't last and can start to rattle just like the iron plugs (if they are not welded in). If you have an iron intake weld the iron plugs into it. Trim them and recess them up into the crossover a bit and weld them up. Recess enough so you don't encroach on the intake gasket surface on the intake. Did mine 10 years ago. Still running strong, zero paint burn, zero carb boiling. I chose this route rather then installing them into the heads. Rather risk trashing the intake over the heads. Don't forget to remove the heat stove flap in the D side exhaust manifold and weld up the shaft holes...if you're still running OEM ex-manifolds. The choke will need a tweak too.
Old Apr 27, 2017 | 12:57 PM
Yeah, but is it $35 worth of "nice"?
Old Apr 27, 2017 | 01:32 PM
Wrong business again!
Old Apr 28, 2017 | 02:06 AM
STLCRZY's Avatar
...if you installed some plates with a gasket (not the stock stile type) donīt think they will rattle
Old Apr 28, 2017 | 05:36 AM
They won't rattle until a hole rots through one or the other...ask how I know this. Yes, they work for a while with the non-turkey gaskets.
dnmfranco
Mar 24, 2014 10:41 PM
dingusboy
Mar 8, 2014 07:09 AM
1977 Delta 88 Flint
Dec 24, 2012 11:25 PM
StickW31
Jan 21, 2010 08:12 AM
bjtstarfire
Nov 13, 2008 02:04 PM
