heads oil drain back holes.
Old Nov 16, 2009 | 10:59 PM
geckonz08's Avatar
whilst oversizing the drain back holes in the heads I have struck the adjacent head bolt hole . Is this a problem ?? Personally, I would have thought not as there nowhere the oil can go . I don`t know if it is the front or rear head bolt hole `cos , excuse the ignorance , the heads look kinda 'ambidextrous'.to me and I don`t know the difference !!!Trust the engine builder knows
The holes were enlarged from 9.5 mm -close to 3/8"- to 11mm -close to 7/16 "
I have cleaned around the breakout , do I have to get a sleeve inserted or is all ok ??
mike
Old Nov 17, 2009 | 06:42 AM
mike
Not sure what you mean by front or rear head bolt hole. The heads are the same from side to side. Breaking through is a bad thing, since it will affect how the head bolts clamp.
Old Nov 25, 2009 | 12:17 AM
geckonz08's Avatar
well I drilled out the 2nd head but only to 10mm and guess what --into the head bolt hole --only 1/2 a mm extra. So 3 out of 4 drainback holes went through to the head bolt hole .
(Info just for those who may be concerned about this possibility --in fact ,it appears , probability ----B heads.)
Old Nov 25, 2009 | 09:01 AM
Run to Rund's Avatar
I have heard of others drilling the drain holes into the head bolt holes without an issue. The oil can't go "anywhere" and the head bolt boss should not rely much on that little piece of wall. I'd debur and run them. I have never personally done this modification, however.
cwb442
Feb 9, 2015 01:39 PM
rootney
Nov 20, 2014 12:39 AM
66-3X2 442
Oct 16, 2014 02:57 PM
brandon 455
Jul 14, 2013 04:16 PM
