Headers
Old Oct 26, 2008 | 07:39 AM
timothypaul's Avatar
Headers
Any opinion on the difference between Hooker Competition Headers versus Doug's Headers (both ceramic coated). Friend used Doug's in his 66 Goat and loves them.
Thanks...Tim
Old Oct 26, 2008 | 03:46 PM
BIGJERR's Avatar
I bleed Oldsmobile
Thanks...Tim
Depends on application but the only diffrence is price Iam betting............Jerr
Old Sep 19, 2012 | 03:26 PM
jfb's Avatar
jfb
Hey i used doug thorleys until i needed bigger tubes,they fit good with a mini starter installed the size was one inch and 3 qters. I now have hooker competition headers 2 and about a eighth thickness but fenderwell headers with super minimal clearance problems and almost non existant problems but a small dent to drivers side 3rd tube for the brake lines and cover it up also the brake line i mean,the drivers upper control arm needs a little trimmed off the bolt make sure u u se lock tite on the nut and of course a mini starter.
Old Sep 19, 2012 | 04:56 PM
442Harv's Avatar
I have Thorleys on my 70 , not coated, they are great, and I use a regular starter.
Old Sep 19, 2012 | 05:40 PM
I'm using the Hooker i 7/8 on my 69, they are 12 years old and still look OK. A lot of the coating has flaked off. They fit extremely well, once the old headers were off these went on in less than a hour. Lots of room with a factory starter.
Old Sep 19, 2012 | 06:13 PM
jfb's Avatar
jfb
dude you really must have gotten lucky. I used a inch and three quarters thorley header and my starter unless you wanted to crush that tube would not fit please post when your thorleys were made and save everbody a couple of hundred on a mini starter.
Old Sep 20, 2012 | 07:01 AM
442Harv's Avatar
Not only do I have a regular type starter, it is a HD Powermaster, and I think it is just a little bigger. It works great, as when I had the GM one, I had a heat shield, and HD spring, and solinoid, this one works great even when hot. I do have to loosen the headers a little to get the starter in or out.
Old Sep 20, 2012 | 07:58 AM
dc2x4drvr's Avatar
The ARH headers Smitty275 sells are IMO, the best, when I pulled mine for engine removal some of the bolts had fell out, and there were NO leaks..but, the starter can't be pulled till the header is at least loosened. These headers fit nice..
Wyze
Mar 18, 2012 01:59 PM
martine
Feb 13, 2007 11:57 AM
JoshF85
Jan 24, 2006 10:20 AM
javi58
Apr 20, 2005 07:53 AM
<72>
Nov 11, 2004 09:09 PM
