header gaskets issue
Old Jul 14, 2009 | 04:09 PM
geckonz08's Avatar
Not going down the "do or don`t need `em " track. I have a copper set of gaskets with a ridge around the ehaust ports. I am surmising these will compress almost flat .This will force the lip into the exhaust area . Some of the lips --about 1/4 " wide are already just on the edge prior to compression. Should I do a dummy run and tighten them (when I get the headers ) ,unbolt them and file the copper back to the size of exhaust on heads ? OR, am I getting a little **** about all this ??
At this juncture ,some time has been spent porting the heads and ofcourse I don`t relish any cu. gasket lips cocking up the airflow !
cheers
mike
Old Jul 15, 2009 | 07:18 AM
Oldsguy's Avatar
Past Administrator
I would do it. **** or not, it is your car and you will be more satisfied if you do it. It surely can't hurt anything.
Old Jul 15, 2009 | 10:08 AM
It might damage the gaskets to torque them and then un torque them. Can they be used multiple times? I think you would get the best seal if you torqued the gaskets and then left them on (only tightening the headers if needed).
Old Jul 15, 2009 | 11:01 AM
The whole point of the embossed bead is to be the sealing surface. If you torque them them remove them, there is no guarantee that they will go back the same way, negating the whole purpose of the embossed bead. If you are really that worried, get solid copper gaskets.
Gbobby
Apr 15, 2016 08:20 AM
Dead Reckon
Jul 14, 2014 02:35 PM
76olds
Dec 16, 2013 02:25 PM
tdubis
Oct 21, 2011 11:45 AM
65az
Mar 28, 2009 09:21 PM
