head gasket
Old Sep 15, 2011 | 08:56 AM
bammer's Avatar
bammer
head gasket
have a 455 engine came out of a 1970 toranado,needs new head gasket,have never done anything like that before,would like to try to save some cash,has edelbrock aluminium heads and intake,if anyone can give me some step by step instructions i would appreciate that thnx Mike
Old Sep 15, 2011 | 09:25 AM
cutlassefi's Avatar
Someone put edelbrock heads on a Toro?! Geez!
Just unbolt the heads keeping all hardware in order. Have the heads checked for straight and make sure you clean all surfaces completely.
You can pick up a shop manual anywhere for cheap, that should help a lot.
Old Sep 15, 2011 | 10:18 AM
nonhog's Avatar
Registered car nut
Not to mention the details that someone here might leave out thinking you would know such things. Lots of guys on here are able to do such a job in there sleep but might not be great at step by step instructions.
Get a manual, you'll be glad you did. Coming from a guy who rely's on manuals.
Old Sep 15, 2011 | 10:45 AM
Mike,
Its not a hard job, it is a long multistep process to try and go into detail on here!! I would also recommend a manual!
Old Sep 15, 2011 | 11:05 AM
bammer's Avatar
bammer
head gaskets
thnx for the advice i will get a manual and fix it myself, also the block came out of a 70 toronado had it built up with some high performance parts.
Bobac455
Dec 4, 2013 09:23 AM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
