Harmonic Balancer Repair sleeve
Old Nov 12, 2017 | 07:56 PM
Turnpike's Avatar
There are several brand options I have found on Rock Auto
Pioneer with no flange
National Redi-Sleeve with flange (which the cup tool uses to install)
Also have read about Speedi-Sleeve
  1. Is there a preferred brand?
  2. If I use the flange style, do I need to remove the flange once installed?
Old Nov 13, 2017 | 08:18 AM
The flange provides an easy way to install the sleeve. The cup tool pushes on the flange, effectively "pulling" the sleeve on instead of pushing it (and risking buckling it). Once in place, the flange gets removed. It is scored so it tears off pretty easily.
Old Nov 13, 2017 | 11:01 AM
m371961's Avatar
I think Speedy sleeve was the first, from SKF. IIRC. If the groove is very deep, it is best to use some metal filler in it before installing sleeve. (JB weld etc.) I then smooth it out. http://www.skf.com/us/products/seals...eve/index.html
Old Nov 14, 2017 | 07:11 AM
Turnpike's Avatar
Great. Thank you for the information
Insom
Dec 6, 2010 04:49 PM
Gert3116
Apr 23, 2008 08:53 AM
bmbraun
Feb 25, 2005 12:17 PM
martine
Apr 2, 2004 09:25 PM
Clint Reno
Aug 10, 2003 10:03 PM
