Harland Sharp Rockers
Old Nov 28, 2025 | 01:50 PM
DanM's Avatar
Awesome User
I got harland sharp rockers for Olds heads years ago. I think they are S5001. While cleaning the heads up and porting more, I went to far and hit a water jacket. Sooo, looks like I'm getting some edelbrock heads. Will these rockers fit edelbrock aluminum heads? Or am I double screwed and also gotta buy new rockers?
Old Nov 28, 2025 | 08:37 PM
Duh's Avatar
Duh
5001 will fit on the head but geometry is less than optimal and you can wind up hitting the stud nut. Also with lift close to or over 600 the pushrod can hit the fulcrum. You can always run a test pattern to see. The best rout is 5016, never had an issue.
Old Nov 29, 2025 | 06:28 AM
DanM's Avatar
Awesome User
dang... anyone want to buy a set of S5001, used for like 30 minutes!
Old Dec 1, 2025 | 09:01 AM
android 211's Avatar
I could probably use them. PM me.
Old Dec 2, 2025 | 04:28 AM
BillK's Avatar
Harland Sharp is working on a new rocker for the newest Edelbrock heads. Call them when you decide to buy them.
Old Dec 2, 2025 | 04:47 AM
rickw30's Avatar
Get a set of 5016. Geometry is beautiful. They have more curve in the rocker. I also had them tool the bottoms of mine. Help's clear the stud nut. I used them with stock valve covers and worked perfectly.
Old Dec 2, 2025 | 05:03 AM
BillK's Avatar
Rick,
I would not depend on that because apparently Edelbrock has changed something on the latest heads. Like I said above Harland Sharp is supposed to be working on a rocker for the latest heads but I don't know if they have them done or not.
Old Dec 2, 2025 | 07:54 AM
DanM's Avatar
Awesome User
A guy at harland sharp got back to me and said they are recommending S4102 for the new Edelbrock heads
Old Dec 2, 2025 | 08:23 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
Don't forget Mark has custom HS rockers that he had made with the ratio stamped on them, they are scalloped, I have a set and there wonderful. I'm just not sure if they will work on the new gen III heads.
New Olds Rockers - ClassicOldsmobile.com
Old Dec 2, 2025 | 11:00 AM
I will be using them on iron 'B' heads with a set of roller lifters
Old Dec 2, 2025 | 11:46 AM
fleming442's Avatar
I had one fall apart (axle and wheel) and couldn't get another single to replace it because they have to wait for another production run to pop up on the schedule. Jesel had me carry spares in 2 weeks. Membership, indeed, has its privileges.
Old Dec 3, 2025 | 04:45 AM
cutlassefi's Avatar
Not sure who you spoke with there, but that rocker is only for the heads i’m doing, they have longer valves in them which changes the geometry a bit.
As mentioned, the 5016 is the one to use for out of the box Edelbrocks. That’s the one I have done for me but with a few minor changes. Right now I only have them in 1.65 or 1.7 ratio. What did you need?
Old Dec 3, 2025 | 09:02 AM
skyhigh's Avatar
What was the cause of this if you dont me me asking?
Old Dec 3, 2025 | 09:23 AM
BillK's Avatar
Who's rockers were those ?
Old Dec 3, 2025 | 11:12 AM
fleming442's Avatar
Harland Sharp, allegedly
Old Dec 3, 2025 | 11:52 AM
BillK's Avatar
I dont think they are Harland Sharp unless they made them for someone else in that color. I dont like the way they are chamfered on the corners where the pin goes through but Marks are like that and I dont think he has had an issue with them.
I bet they are some cheap knockoffs but I could certainly be wrong.
Old Dec 3, 2025 | 12:05 PM
skyhigh's Avatar
The color does look off, I think your right, they look like knockoffs unless he got them from Mark.
Old Dec 3, 2025 | 12:09 PM
rickw30's Avatar
Maybe Mark's are knockoffs also !
Old Dec 3, 2025 | 12:16 PM
cutlassefi's Avatar
Nope, direct from Harland Sharp. Mine say New Olds Performance and are scalloped on both top and bottom.
Old Dec 3, 2025 | 12:33 PM
BillK's Avatar
No I have a set of Marks here and they are definitely different.
Old Dec 4, 2025 | 02:49 AM
skyhigh's Avatar
I think Christian and myself had your first run, they are stamped olds with the ratio but they are more red compared to Flemings set.
Old Dec 4, 2025 | 05:31 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes, haven't installed mine, hoping Edelbrock sends me heads for Christmas. Mine have Olds and the 1.65 ratio.
Old Dec 4, 2025 | 05:34 AM
Rallye469's Avatar
Does comp sell a set for the new E heads?
Old Dec 4, 2025 | 06:17 AM
fleming442's Avatar
They were red; it could be the lighting or green tint from the Penngrade 1. After not being able to get a replacement, I ended up giving the 15 good ones away.
The best part was all the carnage underneath- destroyed the chamber and bore, sent the valve stem into the water jacket, and the valve head through the piston. My best deduction is that the axle slid out, the wheel rolled back, knocking the locks off the valve tip. That was an expensive repair.
Old Jan 5, 2026 | 02:16 PM
JMJ-RIP's Avatar
Mine are from Mark, red, and do say "New Olds Performance" also the ratio.
CuttyShark
Apr 25, 2021 01:59 PM
tmenees2
Sep 13, 2019 08:45 AM
Rocketman!442
Aug 15, 2016 11:22 AM
slow 86
Jul 5, 2014 05:39 PM
Stevec
Aug 10, 2012 11:13 AM
