Got my Carb back!
Got my Carb back!
Well just got my 7029251 carb back from Sparky'S Carbs.....unbelievable how great it looks he does incredible work.
http://www.sparkyscarbs.com/
Try Dean Oliver....Deano's Carb Service. He is very good also. I used him on for my Q jet rebuild.
http://deanoscarbs.com/
He will set it up right. Great guy to deal with.....
It didn't take a year but I think about 5 months. $425.00 for the rebuild and re-plate a previous owner had drilled a hole in the fuel inlet so it had to be welded that was an extra 80.00 if I wanted it to look stock. He tuned it to OEM specs, I haven't put it on yet my engine it is getting rebuilt.
A previous owner drilled the hole, I believe in an attempt to fix the fuel inlet threads as they were stripped. Sparky had it welded and fixed the threads properly.
Oh and I'm in PSL.
Oh and I'm in PSL.
Just a quickie explanation here. YOU CAN'T WELD POT METAL! LOL! Somebody counter bored the inlet and threw in a compression O-ring fitting thread/inlet fix....the KISS OF DEATH! That person also drilled a hole into the inlet snout with a self tapping screw to index/keep the fitting from popping out....very poor repair and also bush league. It was a MESS! Before I heli-coiled the inlet, I re-tapped the hole and used a stainless steel screw to seal the hole with sealer. Then trimmed off the screw head, tapped the 7/8 20 and inserted the heli-coil. I also faced the nose and now is absolutely tight! I took before pictures and will post.
67442nut
December 12th, 2014 06:07 AM
