Got my Carb back!
Old Apr 5, 2013 | 07:53 PM
501Paratrooper's Avatar
Got my Carb back!
Well just got my 7029251 carb back from Sparky'S Carbs.....unbelievable how great it looks he does incredible work.
http://www.sparkyscarbs.com/
Old Apr 5, 2013 | 08:07 PM
In the amount of time it took you to post this you could of had it back on. Now wipe the drool off of it, bolt it back on, and let us know how good it works.
Old Apr 5, 2013 | 08:10 PM
lol!!!!
Old Apr 6, 2013 | 04:25 AM
allyolds68's Avatar
How long did he have it? I just got a quote from Cliff's and they're a year out.
Old Apr 6, 2013 | 04:32 AM
MI68442W30's Avatar
carb rebuild
I second that question , how long did it take from when you sent it to be rebuilt untill you got it back? what did it cost ? and most importantly how well does it perform? inquiring minds want to know!
Old Apr 6, 2013 | 05:38 AM
drop top olds's Avatar
Try Dean Oliver....Deano's Carb Service. He is very good also. I used him on for my Q jet rebuild.
http://deanoscarbs.com/
He will set it up right. Great guy to deal with.....
Old Apr 6, 2013 | 05:42 AM
Here is a picture of my Q-jet after Dean Oliver fixed it....
Old Apr 6, 2013 | 06:21 AM
It didn't take a year but I think about 5 months. $425.00 for the rebuild and re-plate a previous owner had drilled a hole in the fuel inlet so it had to be welded that was an extra 80.00 if I wanted it to look stock. He tuned it to OEM specs, I haven't put it on yet my engine it is getting rebuilt.
Old Apr 6, 2013 | 06:48 AM
brown7373's Avatar
"drilled a hole in the fuel inlet so it had to be welded that was an extra 80.00"
Okay, I have to ask. Why did he drill a hole in the fuel inlet?
Old Apr 6, 2013 | 09:38 AM
A previous owner drilled the hole, I believe in an attempt to fix the fuel inlet threads as they were stripped. Sparky had it welded and fixed the threads properly.
Oh and I'm in PSL.
Old Apr 6, 2013 | 10:38 AM
Bernhard's Avatar
Very nice
Old Apr 8, 2013 | 08:00 PM
Sparkman's Avatar
Just a quickie explanation here. YOU CAN'T WELD POT METAL! LOL! Somebody counter bored the inlet and threw in a compression O-ring fitting thread/inlet fix....the KISS OF DEATH! That person also drilled a hole into the inlet snout with a self tapping screw to index/keep the fitting from popping out....very poor repair and also bush league. It was a MESS! Before I heli-coiled the inlet, I re-tapped the hole and used a stainless steel screw to seal the hole with sealer. Then trimmed off the screw head, tapped the 7/8 20 and inserted the heli-coil. I also faced the nose and now is absolutely tight! I took before pictures and will post.
Old Apr 8, 2013 | 08:46 PM
Sparkman's Avatar
Inlet Repair
Damn....I can't find any pics of the tear down.... I'm just way too busy to take pictures while I'm working lately. But, you can clearly see the repair after plating that I am talking about here. Trust me, I brought this puppy back from the dead!
Old Apr 9, 2013 | 06:16 AM
From the Sparkman himself! Thank again Greg, it came out great!
Old Apr 14, 2013 | 06:12 PM
442rocketdave's Avatar
That carb looks GREAT!! So nice to have someone who does excellent work!!! Good luck with your engine rebuild, how far are you on it??
Old Apr 14, 2013 | 07:35 PM
Thanks, the build is coming along mild porting of the heads now.
67442nut
Dec 12, 2014 06:07 AM
Tedd Thompson
Oct 7, 2014 07:59 AM
65az
Oct 27, 2009 08:50 AM
meoff
Aug 5, 2009 05:50 AM
Redog
Alero
Nov 26, 2008 06:33 AM
