Good oil used?
I heard the zinc content of the Rotella oil was reduced from its previous recipe, but even now it has more zinc than regular oil.
If your using a flat tappet cam with pretty heavy valve springs, I’d suggest using a racing oil like Valvoline VR1. If it’s a well worn engine with a mild camshaft/springs, the Rotella will probably be fine.
Some manufacturers state 5 years as a shelf life. Is it to get us to buy more oil? I don't know. Is the additive package breaking down? Same, I don't know.
It could be to keep users reasonably close to proper modern oil specs for the majority of cars on the road to reduce liability.
Saw a minute amount of "silt" on the bottom of a sealed oil can that had been setting for a very very long time in a shed. Have also noticed the color of oils getting darker that have sat for many years. Maybe that oil was dark in color when they were made.
