Going to pull the 455 / shopping list
Old Aug 27, 2013 | 02:07 AM
EightballZ's Avatar
hey there,
i'm going to pull the engine in some weeks for cleaning, inspection, re-painting and to put some new gaskets in it
engine ran (1)45.000 km ...but was sitting for at least 8 years till i fired her up in 2008...i've already installed new spark plugs, wires, ignition coil, dist. cap, points, water pump, fuel pump, thermostat...
any might-as-wells??
here's my shopping list...what would you add?
- harmonic balancer tools (for pulling / mounting)
- oil pan gasket
- freeze plugs
- exhaust manifold gasket
- timing chain
- timing chain cover gasket
- oil pump
- head gaskets
- intake manifold gasket
- valve cover gaskets
Old Aug 27, 2013 | 03:58 AM
Fullsizelover's Avatar
You are still running points, why not change to HEI?
I guess all new oil/fuel/air filters as well and the carb could use a complete overhaul then it's all good to go.
Old Aug 27, 2013 | 07:01 AM
dfire25's Avatar
"Trying to fix her right"
If you have an automatic and are going to be pulling it together, make sure you find something substantial to cover the end. I pulled my motor and trans last weekend and I used the bag and tape method, it was like a murder scene! . Trans fluid all over the place . I was cleaning it up for hours. Needless to say the bag method works for ****!
Old Aug 27, 2013 | 09:39 AM
Octania's Avatar
Procure a plastic plug or junk yoke from your local trans shop, dealer, or bonesyard. WIRE the yoke in place so it stays.
Old Aug 28, 2013 | 07:32 AM
joepenoso's Avatar
Get a full gasket set........cheaper than buying them one by one
joepenoso
Old Aug 28, 2013 | 10:42 AM
EightballZ's Avatar
thank you guys...
while the heads are ooff...are there any measurements i can do to verify if the engine needs a rebuild?
Old Aug 28, 2013 | 11:29 AM
rcrac3r's Avatar
What is the compression like in the cylinders? May as well do camshaft & lifters while its apart.
Old Aug 28, 2013 | 03:26 PM
EightballZ's Avatar
compression @ operating temp w/ WOT; dry
#1-160
#2-160
#3-150
#4-148
#5-150
#6-150
#7-160
#8-150
would love to do the camshaft...but then i would like to do it right like ebrock heads, lifters, springs, roller rockers...and all that stuff...no headers or aftermarket intake cause its a toronado...would like to keep the qjet....CR is 10,25:1, gear 3.08, street-strip-use, stock converter, stock 15" wheels, 4000+ lbs car
any recommendations?
Old Aug 28, 2013 | 03:32 PM
jag1886's Avatar
I wouldn't do any more than whats on your list. It's the KISS thing people here have been talking about lately.
Old Aug 29, 2013 | 05:52 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You will lose compression if the steel head gaskets are still in it. I would have the heads milled enough to make up the compression loss. You can get .028" Corteco, .038" Mr Gasket and .041" thick Felpro. Your stock gaskets are .017" thick. Cutlassefi is the guy on here for Olds cams and a Mr Gasket dealer.
Old Aug 29, 2013 | 06:20 AM
TripDeuces's Avatar
The transmission will be staying in the car as I assume he's talking about the 70 Toronado in his pic. I would make a bar that crosses in front of the converter to make sure it won't fall out. I guess some stout nylon cord would work as well. Just run it through the mounting bolt holes.
My 70 Toronado weighed 4540 lbs. empty, just so you know.
Although the gaskets are cheaper in a kit the gasket thread on here lists those gaskets that are best to use for each area. Get some Right Stuff gasket sealer too for the trouble spots
The factory bore was 4.126 so if you're close to that I'd leave it. 45k km is roughly 27k miles which isn't much imo. I took my Toronado engine apart around 67k miles and there was a slight ridge at the top of the cylinder but overall it was real nice inside.
Old Sep 24, 2013 | 04:56 AM
EightballZ's Avatar
little update....pulled the engine last weekend...gonna pull the intake, heads and oil pan next weekend..
we'll see
Old Sep 24, 2013 | 05:12 AM
m371961's Avatar
Take note of the ridge. If you have access to the tools, measure the bores just so you know.
Fliplander
Jan 6, 2026 02:55 PM
MDchanic
Paint
30
Jul 7, 2012 10:07 AM
Olds_71_442
Apr 1, 2012 06:11 PM
jslabotsky
Aug 15, 2009 10:30 AM
