Getting the big block parts in order, should I put in the bb front springs?
Old May 24, 2016 | 06:45 AM
Almond900's Avatar
Sold the small block, got the big block, found the 4bbl carb and intake, just wondering if I should do the bb springs too? The guy I got carb and intake from also has a-body bb springs I can get, how much difference is there between the bb and sb springs? He says he has front and rear bb springs, what is the difference in the rear?
Old May 24, 2016 | 11:26 AM
There's no such thing as "big block rear springs", since engine weight has no effect on the back of the car. Cars with the FE2 suspension did get different rear springs, however. As for the front springs, the difference between a BBO and SBO is about 50 lbs. Changing the intake from iron to aluminum just about makes up the difference. I've done the BBO swap without changing front springs, but I think the 68-72 cars sit too high in the front anyway. Have someone sit on the front fender and look at the difference in ride height.
Old May 24, 2016 | 11:32 AM
Almond900's Avatar
That's what I kinda wondered, as it sat with a small block it was about 1" high in front, everyone I talked to around here kept saying they handle so much better but I was worried about it sitting even higher with the bb springs, I was able to find a cast iron 70 4bbl carb and intake so I won't be shaving any weight there
Old May 24, 2016 | 11:41 AM
It really depends upon which springs you get. Some are listed as small block with AC / big block without AC. Just depends upon the spring ratings.
Check this post for the specs I found for Moog front springs as well as a couple pics of my car with front springs that are listed for both SBO and BBO:
https://classicoldsmobile.com/forums...-68-442-a.html
Old May 25, 2016 | 05:56 AM
Almond900's Avatar
Thanks for all the charts guys, this is what I found for springs, fronts are moog 5382 and rear is moog 5385. I guess I am just wondering what to expect for a ride height with these springs. 72 cutlass s 455 all iron no a/c and auto trans. I can buy fronts and rears both new in box for $40 for all, I just don't know what to expect for height from them
Old May 25, 2016 | 06:06 AM
When you swap engines the front will probably drop 1.5 inches. For $40 I'd get the springs. Here is a cross reference to all Moog springs:
http://www.moog-suspension-parts.com...il_springs.asp
Old May 25, 2016 | 06:26 AM
Almond900's Avatar
How do I figure out the dimensions of my stock spring to compare the new spring to?
Old Aug 1, 2016 | 10:37 PM
OldsPerformance's Avatar
I didn't change springs on a few big block converted cars and again like Joe said with the savings on the aluminum intake I beleive the diffenece is a mute point. Good luck
Old Aug 3, 2016 | 06:15 PM
Durf's Avatar
I would drop the motor in and see how it sits with the 350 setup, if you don't like it put the BB springs in. Joe and Olds performance are speaking from experience. My experience was lightening up my 455. Aluminum Heads/Intake, lost the air conditioner. Man she sat really high in the front. The car came with FE2 suspension, replaced with springs for 350 WO air. It still sat high I then cut 1 1/2 coil off the new springs. Like the look much better now.
Old Aug 3, 2016 | 11:52 PM
rad's Avatar
rad
I put a 455 in a nova once, and it sat it right on the headers pretty much, it had a 250 six banger originally, so i put 350 with ac springs in and it actually rode a little high in the front even with a stock intake and iron heads, if it were me id put it in and see where yer at.
Octania
Apr 7, 2016 02:51 PM
Jaap NL
Dec 18, 2013 02:40 PM
Beeks69
Sep 15, 2011 09:19 AM
DEEPCUTT
Aug 13, 2011 08:03 AM
frasco
Body work
Mar 17, 2011 03:39 AM
