Gear Recommendations
Old Aug 1, 2019 | 10:35 AM
Big Features's Avatar
Gang, I have a fairly stock "G" block 400 (71k miles) with the following modifications:
JM 20-22 cam
Edelbrock Performer Intake
QFT 680 carb
1800-2200 Stall converter
Comp Cams roller tip 1.6 rockers with hardened push rods
Hooker Headers with 2.5" exhaust
HEI ignition with MSD 6A box
The stock 12 bolt was rebuilt to include an Auburn positraction unit with the stock 3.07 gears.
At the track, my car ran a best of 9.46 & 73mph in the 1/8th mile.
I would like to get the car a bit quicker, what can I expect going to a 3.42, 3.55, or 3.73 rear?
Tires are 225/60/14s and are about 26" tall.
Old Aug 1, 2019 | 10:49 AM
OLDSter Ralph's Avatar
Define "a bit quicker". Any of the gear ratio's could improve your E.T. At some point, tire spin will need to be dealt with.
Old Aug 1, 2019 | 11:43 AM
How much quicker will my et be with those ratios?
Old Aug 1, 2019 | 01:02 PM
Be aware that if you have an O-Type rear (12 bolt cover, 10 bolt ring gear) there aren't many gear ratios available. Aftermarket there are 3.42, 3.90, and 4.10 gear sets from Richmond Gear (https://www.richmondgear.com/wp-cont...n1.pdf#page=32).
If you have a Chevy 12 bolt, then the ratios you mentioned are possibilities.
sammicurr86
Jan 5, 2017 02:43 PM
sammieolds
Drivetrain/Differentials
Oct 16, 2015 01:17 PM
66-3X2 442
Oct 15, 2014 07:43 PM
2w-30s
May 9, 2013 10:53 PM
michael hilsabeck
Jan 8, 2011 11:38 AM
