Gear drive timing.
Old April 18th, 2014 | 12:06 AM
73aussie455's Avatar
Acceleratii maxim rapidus
Gear drive timing.
Just curious if anyone has any experiences with gear drive timing as opposed to timing chain?
I found this kit for the Olds 455. I'm not thinking about replacing my timing chain, just putting the question out there. As I recall a gear driven cam makes a sweet, although loud, whirring mechanical noise. I'm guessing there would be no issues with a chain wearing out. Would gear driven suit higher HP builds or higher rev's?
What are the pro's v con's of both setups? Interested in your thoughts, opinions.
Old April 18th, 2014 | 07:17 AM
The timing nor the procedure changes with the gear drive. Yes some do sing a pretty tune. They are pretty accurate and eliminate the issues associated with chain stretch.
Old April 18th, 2014 | 08:37 AM
redoldsman's Avatar
Proud Viet Nam Veteran
They sound like a blower. I think I would get tired of it. I guess it depends on the car.
Old April 18th, 2014 | 03:41 PM
Smitty275's Avatar
Engine Builder
If your running massive spring pressures it could make cam timing and ignition timing more consistent. BUT gear drives can also induce unwanted harmonics. I wouldn't waste the time or money on it. I guess it would be neat at the car shows because those guys think a gear drive is just awesome and only used on megga HP builds.
80_cutlass
September 1st, 2018 06:55 AM
71RadioflyerVista
June 28th, 2011 10:11 AM
442scotty
May 13th, 2009 06:42 PM
65cutty
March 11th, 2009 06:14 PM
salayc
December 3rd, 2008 10:48 AM
